Old 22-12-2007, 08:26 AM   #1 (permalink)
bang bang!
Chirag's Avatar
Default Mobo + Procy
Ok first of all my config:
AMD Athlon 64 3200+
Asus A8N-e
160gb Hitachi Sata II
1 gig ram
My system was not starting.. I mean the green light on mobo was coming, fans were working but no display on monitor.. So I called some pc guy and he checked and said that procy not getting power and ur mobo dead.. Is it? The green light is still coming..
Now if my mobo is dead I need to buy a new mobo compatible with my system. I don't use my pc much as m in hostel.. So suggest me the cheapest mobo that would support 3200+.. Yea shldn't be that bad.. Average mobo.. Also what is the cost of Asus A8n-vm and A8n-e??
Chirag is online now
Old 22-12-2007, 12:08 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Mobo + Procy
Is it a socket 939 or am2?
Pathik is offline
Old 22-12-2007, 12:31 PM   #3 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Its 939!
Dude i have a spare MSI motherboard, if u can go for a used one then PM me!
keith_j_snyder2 is offline
Mobo + procy max 10k The Day Walker! Hardware Q&A 1 10-10-2007 02:15 PM
Buying AMD 939 pin Procy xbonez Hardware Q&A 6 16-09-2007 05:41 AM
Help in Buying the Procy Mobo combo! joelf15 Hardware Q&A 12 24-06-2007 11:37 PM
which mobo, procy? xbonez Hardware Q&A 6 06-05-2007 02:04 PM
