Old 22-12-2007, 04:00 AM   #1 (permalink)
Default Plz sugst Vista compatible sound card
My mobo dont have onboard sound.So i want to purchase vista compatible sound card.Plz advise me that sound card which is better than current generation motherboard onboard sound(intel 965,G33 etc).
piyush1989kap is offline
Old 22-12-2007, 08:03 AM   #2 (permalink)
Gizmo Freak !
spitfire's Avatar
Default Re: Plz sugst Vista compatible sound card
Mobo without onboard sound ???????????????!!!!!!!!!!!!!!
Which mobo do you own dude ?
By the way whats ur budget for the card ?
If its around Rs 500 then go for Realtek prima which is based on ALC888
If its around 1-1.5k then go for Audigy value 7.1 24bit
if you can shell out over 2.5k then get an Audigy2ZS which is the cheapest card that has its own DSP
And if you have around 8-15k then look at the x-fi series..
spitfire is offline
Old 23-12-2007, 02:05 AM   #3 (permalink)
I want a sound card which is at par or slighlty better with intel HD audio.?????????
Is audigy value better than intel???????
Old 23-12-2007, 07:32 AM   #4 (permalink)
sidewinder's Avatar
yes..it is much better with full eax support and thats the cheapest you get from creative !
Bombina rocks
sidewinder is offline
Old 23-12-2007, 11:51 AM   #5 (permalink)
I never used a seperate Audio Card lol.
Anyway I only use it for games and use headphones so a realtek HD Audio onboard is more than enough.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Windows Media Center VISTA Compatible TV card! freshseasons Software Q&A 11 02-08-2007 11:12 AM
Get ready for Windows Vista: Cheapest Vista compatible PCs gxsaurav Hardware Q&A 15 31-03-2007 03:26 PM
AC97 Integrated Sound Card Issues in Vista RTM sinstoic Software Q&A 2 03-12-2006 04:26 PM
My Creative 24Bit creative sound card not working in windows vista.... selvamcbe Software Q&A 2 05-11-2006 12:11 PM
