Old 22-12-2007, 02:32 AM   #1 (permalink)
Question unique problem with my desktop
hi all
i have a strange problem with my desktop.....
the configuration is....amd x2 4200+, asus m2nmx motherboard, transcend 2gb ddr2 memory, seagate sata hdd.....
the problem is that intermittently the computer hangs while a beeping sound is heard from the cpu.....there is no specific activity which causes this problem...it is random and intermittent......at this time the keyboard stops responding but the mouse is functional for some time after which it hangs too......
the machine works well after switching off for some time......
i have shown to 2 different techs but they thought th problem was software related.......
the comp has been formatted once for this purpose but the problem is recurrent.....
can anybody guide me in this matter.......
vipulchem is offline
Old 22-12-2007, 03:07 AM   #2 (permalink)
CG Artist
gaurav_indian's Avatar
Default Re: unique problem with my desktop
Originally Posted by vipulchem
hi all
DAMN IT.I am facing the same problem.I dont know whether its a hardware problem or software problem.Its giving me headache.I have formatted my drive thousands times.
And i thought i was the only one facing this f****** problem.Can u tell me what software you have on your system?I formatted my drive (i dont know how many times so far ),checked it for two days without installing any software which i thought might be causing problem.But still sometimes i think its a hardware problem sometimes it looks like a software problem.
gaurav_indian is offline
Old 22-12-2007, 09:59 AM   #3 (permalink)
Anindya's Avatar
Thumbs up Re: unique problem with my desktop
Just last leek even i faced this type of problem. The pc freezed at random interval! So i had given the solution in which i solved it in my blog. If u wish then plz check out. Its a hardware problem.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 24-12-2007, 10:02 AM   #4 (permalink)
Question Re: unique problem with my desktop
hey gaurav i have contacted the amd and asus tech support too....hopefully they will get back to me...apparently this problem cannot be tackled by our local computer guys.....
by my guess most probably theres a heating problem and the solution lies in the cabinet and thermal gel....but this is just my guess...
whats your pc configuration???
please keep me updated about anu solutions you might come across and i will do the same....
Old 24-12-2007, 01:30 PM   #5 (permalink)
a_tif's Avatar
Lightbulb Re: unique problem with my desktop
I had a similar problem but mine was due to my sata hdd power cable
the hdd would give a beep and stop responding n system would hang
changing cables did the trick for me
a_tif is offline
Old 24-12-2007, 01:48 PM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Open up everything n try reinstalling all wires n cables........ should solve it
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 24-12-2007, 05:51 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
Open up up & clean every hardware components. Reinsert them properly.
Also it could be ram problem. I faced exactly same probs with my old rig with starlite ram. Bought 2
new zion ram & my probs solved
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Unique Problem nishant_nms Hardware Q&A 4 19-07-2006 02:53 PM
SNMP heating up - new unique problem...!!! sincereheart QnA (read only) 4 25-07-2005 11:17 AM
unique problem in Win98 harshagarwal Software Q&A 5 21-10-2004 07:58 AM
Unique TV Tuner Problem (Short Circuit @ Home) quad master QnA (read only) 6 26-08-2004 02:02 PM
