Old 21-12-2007, 11:54 PM   #1 (permalink)
Smitten by Computers..
raptorz's Avatar
Default Which RAM for Pentium D 805
I have an old Pentium D 805 on Intel D945GNT Motherboard, with 1 GB DDR2 533 Mhz RAM..
I am planning to add another GB. I have read that Pentium D 805 has 533 Mhz FSB, Can it support 667 Mhz RAM?
Can I use 667 Mhz, with my existing 533 Mhz Module?
There were somethings Man was never supposed to know, for everything else there is Google..
raptorz is offline
Old 22-12-2007, 12:17 AM   #2 (permalink)
j1n M@tt's Avatar
Default Re: Which RAM for Pentium D 805
Even if ur proc has only 533MHz FSB u can use 667MHz RAM and u can use it with d older one but not in dual channel;but d 667MHz RAM will only run at 533MHz together with d older one.If u haf 2 use dual channel, u haf 2 get 2 identical RAM modules of 667MHz RAMs.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 22-12-2007, 12:27 AM   #3 (permalink)
raptorz's Avatar
I already have 2x 512 MB 533 Mhz Modules in Dual Channel Mode..
I am confused whether to get 2x 512 MB 667 Mhz Modules in Dual channel or 1 GB 667 Mhz Single Module..
I have also read that, 667 Mhz performs a just a little better than 533 Mhz in benchmarks.. I am thinking of getting 533 Mhz itself..
raptorz is offline
Old 22-12-2007, 12:44 AM   #4 (permalink)
Google Bot
Pathik's Avatar
Sell off ur 2 modules. And get 2*1gb ddr2 667mhz 4 1.8k
Pathik is offline
Old 22-12-2007, 12:58 PM   #5 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
U can use the same with 1 GB module but it will not work in Dual Channel.
For dual channel u should have identical RAM modules!
keith_j_snyder2 is offline
How is Pentium 4 3.2GHZ with HT diffrent & faster than Core 2 Duo and Pentium D. I Do Not Have A Username. CPU / Motherboards 12 22-11-2006 09:26 PM
40 GB HDD ON PENTIUM mmx ArZuNeOs Hardware Q&A 3 22-11-2005 09:55 PM
pentium 4 3.4 ghz yogi7272 QnA (read only) 17 22-09-2005 09:41 AM
Pentium 4 vs Pentium Mobile . The confusions ? FxBOOM QnA (read only) 12 14-09-2005 06:39 PM
IDF 2005 started, Pentium 4 is now Pentium D gxsaurav QnA (read only) 5 04-03-2005 06:40 PM
