Re: Routing
ok then it will work , connect ur xbox to the hub,and also ur pc and friends pc to hub as said earlier, all the the three(pc1,pc2 & xbox) can connect to net simultaneously.
In modem DHCP settings ,set the start ip as 192.168.1.3 and end ip as 192.168.1.4 , and assign these two ip's to ur pc & xbox and give ip 192.168.1.5 to ur frind(he will not be able to use the net,but both of u can share files each other).If possible use a switch instead of hub for faster file transfer(intex switch cost Rs750/-)
My Stomach pains:D:D
http://tinyurl.com/32jj4m
