Old 20-12-2007, 11:51 PM   #1 (permalink)
At Learning Steps
arun_0710's Avatar
Question What's the problem?
I have system configuration of Intel Celeron 1.0ghz, Intel 810 chipset, 2*128 ram, with windows xp(sp2). I used to hibernate my system often, as it saves a lot of my time. the problem now is whenever i hibernate my system, it goes fine but the next time i start my sys. it does not start, it neither even shows the boot screen. the power comes for a few sec, the processor fan starts and then it goes back.
I tried with checking my smps to be the faulty one but the smps is working fine with my friend sys.
So, is the prob now with my mobo or processor? plz help me out of the prob.
arun_0710 is offline
Old 20-12-2007, 11:58 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: What's the problem?
I think when restarting ur pc grom hibernated state, there is not enough space on RAM to load the files stored on the HDD. Increase the RAM and check again if u can.
debsuvra is offline
Old 21-12-2007, 12:15 AM   #3 (permalink)
anand1's Avatar
HAve you tried to Turn Off ur system and post then.
Technology On The Fly
anand1 is offline
Old 21-12-2007, 12:22 AM   #4 (permalink)
moshel's Avatar
just turn off ur PC (even from the electrical socket) for a good 5-6 hours then try...
u cud try by removing the CMOS battery also...even though the chances of that creating a problem is less....but nothing bad in trying it.
moshel is offline
Old 21-12-2007, 12:36 AM   #5 (permalink)
At Learning Steps
arun_0710's Avatar
I tried shutting down my pc, in this process there is no problem faced while restarting, the prob occurs only when it is either hibernated or it is shut down by ctrl+shutdown option from windows task manager. while the problem occurs no option works but only leaving the pc as it is for 2-3 hrs. and then start again. I have cheked the cmos-battery, smps, ram all of them., all r in good state n working fine.
Old 21-12-2007, 12:41 AM   #6 (permalink)
anand1's Avatar
Have you installed any hardware or uninstalled any of the software?
It seems there is some system file change, go for running system file checker utility.
anand1 is offline
Old 21-12-2007, 12:46 AM   #7 (permalink)
At Learning Steps
arun_0710's Avatar
no, i had not done any kind of a hardware or software change, rather i tried to solve the prob by installing windows xp(sp2) again thinking of it may be a software prob, but the prob still continuesssss...............
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
