Re: Plzz Help its urgent
well if you are ok working with pc hardware you could take the case off find the little battery that keeps a charge going to your bios,Well, removing battery can be dangerous, battery may leak if unproperly taken off, so don't remove battery,you can esaily break plastic that battery is kept in. I recommend clearing CMOS. Shorting two pins up 10 sec. will do it
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
