Old 19-12-2007, 06:43 PM   #1 (permalink)
Ranjya's Avatar
Unhappy Boot Problem
I have a 6yrs old P-3 866MHz, 128 x 2 SDRAM, GeForceFX5200 PCI graphic card on
i810e Kranion motherboard with a 20GB Seagate HDD.
Since 10 days all the OS's (WinXP-Pro, Fedora 7& Suse10.3) stop booting at random
stages.
The monitor light goes orange i.e no video feed.
Is this HDD problem ? After OS boots no problems.
Is this RAM problem ? I tried memtest86...test2 Pass.
Is this Powersupply problem.
It has to be hardware as different OS are involved.
Help!!
Suggestions!!
Ranjya is offline
Old 19-12-2007, 07:29 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Boot Problem
most probably its a ram problem
is it only with the os or nothing is shown?unplug the monitor from ur pc and u should see a No signal display on ur monitor if its right.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 19-12-2007, 09:17 PM   #3 (permalink)
SivaChand
Which ram you are using? May be ram slot have dust...
kpmsivachand is offline
Old 19-12-2007, 09:43 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Do you hear some beeps at startUp???
If yes...count all small + long beeps.
ravi_9793 is offline
Old 22-12-2007, 06:06 PM   #5 (permalink)
Ranjya's Avatar
Why RAM ?
My PC boots sometimes.
Once it boots it keeps on working.
This is a boot time problem only.
During a greyout my daughter had repeatedly
cold booted PC. I think some vital HDD space has
been damaged.
I am going to get new HDD.
Ranjit.
I get just 1 beep....OS starts to load and inbetween monitor
light goes yellow.
This happens randomly in the boot process of all OS.
No Beeps or I would have thought of defective RAM.
regards,
Ranjit.
Ranjya is offline
Old 24-12-2007, 10:53 AM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try removing & cleaning ur RAM & its slot ..... & then plug it again .....
try whot @nish_higher ...... said ......
& if u think ur hdd has a problem, check @ ur frds\relative\neighbours place .....
... W H O T ...
ax3 is offline
Old 24-12-2007, 02:01 PM   #7 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Try cleaning ur ram......use some eraser..... n then reinstall them...should solve the problem
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
boot.ini problem pramodv1988 Software Q&A 8 20-11-2007 09:26 PM
Boot Problem ojha_riddhish Hardware Q&A 4 02-11-2007 06:08 PM
boot from cd problem+reboot problem anilmm2006 Software Q&A 2 01-09-2006 11:03 PM
Boot Problem Brainstormer Hardware Q&A 1 31-08-2006 04:57 PM
boot up DVD ROM problem ?? Choto Cheeta Software Q&A 3 09-01-2005 10:23 PM
