Old 18-12-2007, 03:49 PM   #1 (permalink)
The Demun
Sinja's Avatar
Default GeForce 8600GT will it work on xp system with directx 9 to the fullest
or does it work only on vista systems with direct x 10.
i run a xp system with DirecX 9.c
was planing to buy gfx card but need to know if it works best with windows XP.
if not this
wat is the best graphics card for windows xp with direct x 9.c
i am deeply sory if i have made a new topic for this but i could not find any info on
8600 its performance and compatibilty with xp on direct x 9.c
Ragnarok is a way of life ^_^
Join the wonderfully addictive world of ragnarok be a Rag addict the ultimate addiction in MMORPG
Sinja is offline
Old 18-12-2007, 03:58 PM   #2 (permalink)
Default Re: GeForce 8600GT will it work on xp system with directx 9 to the fullest
no,it gives decent performace on xp too with all games playable at highest setting except some kiler ones like crysis.
if ur budget is arnd 5-6k then get a xfx 8600 GT
SunnyChahal is offline
Old 18-12-2007, 04:08 PM   #3 (permalink)
~[::BOoYaKa::]~
Is crysis playable with low settings and all eye candy off on it?
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 18-12-2007, 04:10 PM   #4 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^yep,why low settings?I think it can manage medium settings at playable framerates.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 18-12-2007, 04:13 PM   #5 (permalink)
yeah playable (35-37) FPS on 1024*768 wit hall settings to med and no AA.
Old 18-12-2007, 04:15 PM   #6 (permalink)
The Demun
Sinja's Avatar
okiii i only know of 2 8600's
8600 GT
8600 GS
wats xfx 8600GT?
its from the same company?
i just wana know if it works well with direct x 9 coz all the xp based games are on direct x 9.
i dont like vista ........... or directx 10.
Sinja is offline
Old 18-12-2007, 04:19 PM   #7 (permalink)
I run XP SP2. 8600 GT works perfectly fine. It runs DirectX 9.0c Games without any probs. Also It is able to run all DX 10 games.
It runs fine on Vista also with all the eyecandyAero turned on. Go ahead no probs.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 18-12-2007, 04:19 PM   #8 (permalink)
first theres nothing like 8600 GS.
there is 8600 GT and 8600 GTS(a bit more costlier than GT)
and yes mann 8600 GT works very well with dx9.i myself am using 8600GT.
and XFX,ASUS,zebronics,BIG are the gpu manufacturers and distributors.
get XFX 8600GT .costs 5.5 K
Old 18-12-2007, 04:20 PM   #9 (permalink)
no 8600gs
xfx==conpamy that make graphic cards
8600gt==model no. of graphic card
it works with both XP and Vista without any problems but you need to use vista if you wanna play dx10 games.
now enough of noobish questions.Google is a good start to noobish questions.
Old 18-12-2007, 04:21 PM   #10 (permalink)
XFX is one of many ompanies of graphic cards.
Buy 8600 GT which is made by XFX.
8600 GS? No such card as far as I know
Tech_Wiz is offline
Old 18-12-2007, 04:40 PM   #11 (permalink)
The Demun
Sinja's Avatar
can any one tell me wat is the current price of
Nividia 8600GT
and xfx 8600GT
and xfx and nvidia are the same?
Sinja is offline
Old 18-12-2007, 04:50 PM   #12 (permalink)
mann now this is tooo much.even a 14 yr old like me knows whats nvidia nd whats xfx.
ok ,xfx is the graphix card manufacturing company which uses chips manufactured by nvidia to make their cards.
nvidia only makes chips and rest of the card is manufactured by these companies like xfx or asus.
ok??
and xfx 8600 GT costs 5.5-6K.
Old 18-12-2007, 05:02 PM   #13 (permalink)
The Demun
Sinja's Avatar
ok im sory im not much aware of it.
but i have heard Nvidia Geforce 8600GT is like 8k
so i dont understand that xfx is making graphics card and selling for 5.5k
GeForce is the graphics card using nvidia chips?
is Geforce a brand of Nividia its own graphics card manufacturing company?
its similar to xfx??
what is the best company to buy nvidia 8600GT graphics card
please dont be angry with me coz i really dont know am sory for my ignorance.
Sinja is offline
Old 18-12-2007, 05:06 PM   #14 (permalink)
i cant help u yaar.u ask too much noBish questions.
ok do as i say.
fill ur pockets with something like 7k.
go to any good comp hardware market.
ask the retailer to give u xfx 8600 GT 256MB.
give the money get the bill come home.install the card.if u get any problems in installing then refer to the manual provided or call a hardware guy.he ll do the work for u.
then switch ur comp on install the drivers provided on the cd and u r ready for gaming.
NOTE:first check if ur mobo is pci-e or AGP compatible.this is very important.
i think u wont have any probs now.
Old 18-12-2007, 05:30 PM   #15 (permalink)
hahahari's Avatar
ok do as i say.
good one
www.harivarrier.com
Check out to earn money...
hahahari is offline
Old 18-12-2007, 05:32 PM   #16 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Hey, why do you get angry? Some learn quick, some don't. Remember everyone was a n00b. Dude, Sinjan. Do one thing. I think with your limited knowledge, if you go to a computer dealer, he'll loot you. I think that's the reason you have heard the price as 8k.
Coming to your other queries.
GeForce is the graphics card using nvidia chips? is Geforce a brand of Nividia its own graphics card manufacturing company?
Read more about it here
I think you might have understood what GeForce is by now. So, XFX is the name of the company like Asus, Gigabyte, MSI, etc. You might have heard about these companies, which mainly manufacture motherboards for Intel and AMD. In the same way, XFX manufactures graphics cards with nVidia chipsets on it. Got it?
BTW, what's your age? It's ok even if you are old. Don't feel shy or get depressed. Many of my friends who are aged 22 and above don't know a lot about hardware
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 18-12-2007, 08:12 PM   #17 (permalink)
absolutely right.
i was not getting angry yaar but it was toooo much nooBish.thats why.......
i get angry very soon.so plz dont mind my words but hey sinjan ull have no probs if u do as i say.
but check different shops for the least price.5.5k or so.
Old 18-12-2007, 08:35 PM   #18 (permalink)
dOm1naTOr's Avatar
nvidia dun make cards by themselves.....even if they make, then they are only reference cards like those used for testing,benchmarkin nd given out for reviewers.
Here in India the best Graphics card makers are XFX, ASUS, MSI etc.
There are versions of 8600GT which come close to 8k. They are company overclocked nd has many features like gud copper heatsink or fanless design or factory overclocking etc.
If u sure that u not gonna use vista, then u can get far better performing cards at a lil more cost.
U can consider cards with GPU 7900GS for some 8~8.5k from nvidia nd u can look for brands like XFX, ASUS, MSI etc.
Or a better card id ATI 1950 pro for some 9k. They are best performers among DX 9.0 cards.
U can use these cards even in vista and enjoy all games but with only DX 9.0 eye candies even if u use vista..
Hope this clears ur doubt.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 19-12-2007, 10:45 AM   #19 (permalink)
The Demun
Sinja's Avatar
i ave just come to realize
Nividia GeForce 8600 GT is just a Chipset wich is a part of a Graphics card
basically Graphics card manufactures take Graphic chipsets and add other components like heatsink and make an over all graphics unit.
and sell them .
T_T now i realised eeet.
Now i gotta decide wich company Graphics card to go for and wich price is eet.
oki i realized i dont ave tat much cash at hand >_<
can any one tell me wich company brand xfx ,asus,msi
offers the cheapest and best graphics card using geforce 8600 GT chipset.
sunny is saying xfx offers it at 5.5 then at 7k ( im little confused here as to actual rate) wich one is right? and any thing else better ?
please can u suggest me a cheep and best company graphics card and if u can tell me the cost.
@all
thank u guys now i understand what is what basically.
>_< like sunny said i dun wana get looted on soem thing expensive
Sinja is offline
Old 19-12-2007, 11:07 AM   #20 (permalink)
phreak0ut's Avatar
Buy an XFX 8600GT ONLY if you have PCI-E slot, else you can go for any high end card for AGP slot. Simple as that. Why are you getting so confused even after so much of explaination?
Old 19-12-2007, 01:25 PM   #21 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
There is an 8600GS card.Just look around the driver download section of nvidia.
Harvik780 is offline
Old 19-12-2007, 03:43 PM   #22 (permalink)
@sanja-here in Delhi at nehre place we can get XFX 8600 GT 256 MB for 6k or arnd.
the price differs with respect to ur location as well but it must not be more than 7 k anywhere.
@Harvik,yaar i have never heard of 8600 GS.
Old 19-12-2007, 06:11 PM   #23 (permalink)
The Demun
Sinja's Avatar
well its a chipset wich is available in the 8600 series by Nvidia
there are 3 versions of 8600 chipsets
GT GS GTS
these chipsets are used by the chip making companies as u told
xfx has favoured the use of GT type .
with its brands of xfx 8600GT
and its own upgraded version GTX.
Sinja is offline
Old 20-12-2007, 10:07 PM   #24 (permalink)
@sinja
There is no 8600 GS. We have only GT and GTS.
but for sure, there is 8400 GS.
Check these pages:
http://www.nvidia.com/object/geforce_8600.html
http://www.nvidia.com/object/geforce_8400.html
ico is offline
Old 20-12-2007, 10:09 PM   #25 (permalink)
Originally Posted by gagandeep
@sinja
Check these pages:
there is a 8600 GS card.
check in nvidia drivers list
Old 20-12-2007, 10:49 PM   #26 (permalink)
deathvirus_me's Avatar
NVIDIA_G84.DEV_0403.1 = "NVIDIA GeForce 8600GS"
^^ from nv4_disp.inf .. 8600GS do exist ...
deathvirus_me is offline
Old 20-12-2007, 10:53 PM   #27 (permalink)
Rebooting
Choto Cheeta's Avatar
I support aravind_n20, when plaing to stay under DX 9.0c platform, its better to buy 7600 GT / GTS or equivalent ATi Cards
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-12-2007, 12:42 AM   #28 (permalink)
moshel's Avatar
go for the XFX 8600GT only...if u dont have dat much money go for the one which im using (check my Siggie)...
Digit wrote in its review that it is as good as a 8600GT.
the card im using is Asus 8500GT256M EN SILENT.
the term silent means that its a fanless design.
not meant for overclocking but performance wise very good.
moshel is offline
Will my motherboard support GeForce 8600GT arun77574 Hardware Q&A 23 09-09-2007 03:37 PM
Radeon HD 2900XT beats Geforce 8800GTX in Call of Juarez DirectX 10 Benchmark! Stalker Gamerz 8 04-07-2007 12:13 PM
My new Gainward GeForce 6200 doesn't work! Ramstrong Hardware Q&A 1 16-10-2006 12:47 PM
