Old 18-12-2007, 01:04 PM   #1 (permalink)
Default will This RAM work in Dual
see the two pics of RAM config will they work in dual mode
sAn web creations 2006
contact: sanolution@gmail.com
sanolution is offline
Old 18-12-2007, 01:12 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: will This RAM work in Dual
yes..it will work.
Conditions for dual channel:
1) Motherboard should support. (Read manual of motherboard for this)
2) Both RAM should be of same frequency and storage capacity.
ravi_9793 is offline
Old 18-12-2007, 01:20 PM   #3 (permalink)
i agree it has same latency but different RAS# to CAS# and RAS# precharge
is that ok
Old 18-12-2007, 01:21 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yes...
you can use in dual channel.
Work, Work & Work.... u get no raise ! vish786 Chit-Chat 5 14-09-2007 03:49 PM
my DVD rom Not work vikasg03 Hardware Q&A 6 04-01-2007 09:28 PM
dual boot from dual harddisk?? spyder Software Q&A 10 09-04-2006 10:05 PM
Intel dual core without HT or AMD64 dual core--which is best vps85 CPU / Motherboards 2 26-04-2005 01:02 AM
