Old 18-12-2007, 11:38 AM   #1 (permalink)
Livin my Dreams
kanu2k7's Avatar
Post Help!!! CPU Multiplier gone crazy
Hi!!!
i read this month issue and about the topic OVERCLOCKING in the Computing Mag of the DIGIT December issue.
My PC Configuration is:
Pentium D 925 3.00 Ghz ,800Mhz FSB
CPU
2x1 GB DDR2 @ 667 MHz (Kingston) Ram
ASUS P5GZ-MX (945 Chipset) Motherboard
160 GB Hard Disk
Jetway Graphic Card (Nvidia 7300LE 256 MB)
Matrix Cabinet with 400 Watt SMPS
and some miscellenous stuff
I have a benchmark utility i.e. Lavasoft EVEREST which shows the following results after a minor overclock of 10 MHz in CPU FSB speed.
My probem is that the CPU Clock speed which is 3000 Mhz is being showed 2519.9 Mhz before overclocking at CPU FSB speed of 200 Mhz the CPU Clock Speed showed 2399.9 Mhz !!
Why is that?
And also after some intervals the multiplier jumps to 15.0x from 12.0x which increases the CPU Clock Speed to 3159 Mhz after overclocking and before overclocking it showed 3000 Mhz at the time of multiplier change.
What is happening to my PC plz someone tell me???
this is a Screenshot of my voltages
kanu2k7 is offline
Old 18-12-2007, 07:57 PM   #2 (permalink)
4Ghz Here I come !
Demonkiller's Avatar
Default Re: Help!!! CPU Multiplier gone crazy
I dont know about PD's but most intel procy's have Speed Step Enabled.
Check in the Bios if there is a value EIST and disable it. That should solve your jumping multi.
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
Demonkiller is offline
Old 19-12-2007, 12:38 AM   #3 (permalink)
Livin my Dreams
kanu2k7's Avatar
Yes i'll try that!!!
THX
I have disabled the speed step option in the BIOS but to no avail!!!!!
PLz Help
I have noticed that the multiplier comes up when i put load on the processor like minimize and maximize a window it stayed at 15x but when i stoped minimizing and maximizing a window it again returned 12x multiplier.
I seriously need some assistance!!!
Plz
kanu2k7 is offline
Old 19-12-2007, 04:00 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
I have exactly the same same CPU.
Just disable Speed Step & C1E Enhanced halt state in bios
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-12-2007, 04:10 PM   #5 (permalink)
Deadman Walking
Batistabomb's Avatar
stop the Speed Step & C1E throttler
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 20-12-2007, 07:34 AM   #6 (permalink)
Livin my Dreams
kanu2k7's Avatar
Thumbs up Re: Help!!! CPU Multiplier gone crazy
yeaaaaaaa!!!!!!!!!!
Thank you guys!!
its now done!!
thx thx
kanu2k7 is offline
Old 21-12-2007, 04:40 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ Dude, Great to know that your problems are solved
topgear is offline
mtnl just got crazy with me!! napster007 Software Q&A 14 20-06-2007 07:04 PM
outlook gone crazy manishji Software Q&A 3 26-08-2006 01:48 PM
crazy thread? Raaza Mobiles and Tablets 11 27-07-2006 10:40 PM
My Norton has gone CRAZY!!!!!!! tukaibatman Software Q&A 1 23-10-2005 06:38 AM
Dataone gone CRAZY !!! mohit Broadband and DTH 19 05-10-2005 11:56 PM
