Results 1 to 2 of 2
  1. #1
    Dec 2007
    Default HDMI for best video quality.
    HDMI as many are aware is the latest HDTV physical layer standard. It provides true ALL digital video and audio transmission.
    You definatly want to use HDMI when connecting your HD source to the HDTV for best picture quality.
    However, many TV are only being equipped with 1 HDMI input which is inadequate. You can use a HDMI switch. Which allows you to switch between multiple HDMI or DVI sources to 1 HDTV.
    A HDMI splitter, on the other hand, will show a HD source or computer to 2 HD monitor.
    You can use a HDMI splitter, it has 1 input and 2 HDMI outputs that lets you mirror both pictures on both displays. You don't need to do any switching, it will just show up on both displays.
  2. #2
    Juke Box Hero
    Aug 2007
    Default Re: HDMI for best video quality.
    HDTV? HDMI?
    Sorry but I'm a poor ba$tard who hates ad spammers!!
    Reported.
  1. HDMI Noisy video output in DELL STUDIO 1535
    By harshsaini in forum Graphic cards
    Last Post: 20-02-2011, 10:06 PM
  2. Does HDMI cable give better quality than DVI?
    By blademast3r in forum Hardware Q&A
    Last Post: 08-12-2010, 01:40 PM
  3. Quality problem with video cd
    By kushals in forum Software Q&A
    Last Post: 25-12-2007, 01:07 PM
  4. Replies: 4
    Last Post: 21-09-2007, 08:05 PM
  5. How to get good quality video recording
    By skarun in forum Software Q&A
    Last Post: 22-03-2005, 12:04 AM
