Originally Posted by jal_desai
format it from the command line... i had the same prob..i formatted it from command line... in the command line go to the drive and write "format" ..
dude he has already told that he used command line.....not working.....
@Dhruv , I suggest you to try the drive on another computer (try it on your friedns comp
OR there might be some problem in ur usb mass storage and root hub drivers .
do this (reintalling usb root drivers)
1. remove your pen drive
2. right click my computer
3. go to device manager in hardware tab
4. unistall these all marked with red
here
5. reboot ur computer
6. plugin the pen drive
7. the drivers should be automatically be installed again .
8. now try to format it
if it doesn't works ..........do what i said first .....
Thanks
Regards.....
Expertno.1
