Old 14-12-2007, 05:18 PM   #1 (permalink)
4Ghz Here I come !
Demonkiller's Avatar
Default Computer Not Booting Up!
Well, here's the thing, I noticed that my C drive was running out of space too fast, all the files occupied 3 GB or so. And the partition is of 30gb, and there was only 1GB free space, Decided to format and do a clean install of Vista again. Was trying to install the beta 2 disk since the OEM one gives me a cannot install one or more devices error and shuts down.
Comp was running fine, installation begun, and about halfway through, comp unexpectedly shut down. After that I cant seem to even get it to boot up. The MBD light lights up once I turn on the main supply, but when I try to switch it on, nothing. I checked all the wires connected to the comp, was nothing. I tried switching out the ram with my mom's and checked, still nothing.
Any help?
Rig Specs in my sig.
Got a 400W PowerSafe PSU.
Regards,
Demonkiller
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
Demonkiller is offline
Old 14-12-2007, 05:29 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Computer Not Booting Up!
you had graphics card , isn't it, so from where are you booting from,from hdd or from graphics card ?
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 15-12-2007, 12:52 PM   #3 (permalink)
4Ghz Here I come !
Well I'm supposed to be booting up from the installation CD. But I cant even seem to get it to turn on for 1 second.
Anyone?
Any help would be appreciated.
Old 15-12-2007, 02:21 PM   #4 (permalink)
Ranjya's Avatar
Cool Re: Computer Not Booting Up!
do you see the bios screen?
do you hear beep before boot?
check your bios battery otherwise.
Ranjya is offline
Old 15-12-2007, 02:58 PM   #5 (permalink)
Software Engine
chandru_skc's Avatar
can u see the boot screen... ???
chandru_skc is offline
Old 15-12-2007, 08:37 PM   #6 (permalink)
4Ghz Here I come !
Well It doesnt even poer up. Only mbd led lights up. Nothing else. Even when I press the power switch,nothing.
Well If I dont get any help, I could as well ask my compy guy to check it out. Have exams on monday and dont have much time to troubleshoot it,
Any Help regarding this?
Old 15-12-2007, 11:42 PM   #7 (permalink)
You mean the cpu fan also doesn't spin up when powered.......indicates a smps problem.Borrow a smps from a friend and check.
Let there be music.....
sashijoseph is offline
Old 16-12-2007, 12:36 PM   #8 (permalink)
4Ghz Here I come !
Unhappy Re: Computer Not Booting Up!
Thats the most likely cause. It rebooted like 5-6 times halfway through the Vista install. LOL. Abt my friends no1 has anything near a 350W psu. And half of them wont even want to open up their computer "Dubba"
Old 16-12-2007, 01:14 PM   #9 (permalink)
can i boot from graphix card ?
Faun is online now
Old 16-12-2007, 03:12 PM   #10 (permalink)
dOm1naTOr's Avatar
@T159
load DSL into vram.....
support
II
II
V
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
help!! pc not booting HEMANTRATURI Hardware Q&A 3 07-06-2007 09:13 AM
My computer is not booting kishan Hardware Q&A 7 18-01-2007 05:03 AM
Computer hangs after booting Pravin Software Q&A 8 23-12-2006 10:49 AM
pc booting again n again gycapri Software Q&A 10 11-03-2006 09:09 AM
computer booting stops for 3 seconds bishnu_rath Software Q&A 4 06-03-2005 10:14 PM
