Guys i'm havin a strange prob.with my Benq DVD ROM (combo) ,that is if does not play certain DVD'S and these mostly consits
of CHIP COVER DISKS AND DIGIT COVER DISKS AND MOREOVER they are of the current month only (dec'07).
only 1 of 4 cover D of chip (dec'07) work and 2of 5 COVER Disc of DIGIT MAG (DEC'07) WORK.the strange thing it that
other cd's and dvd's play quite easily be it of chip (except dec'07) or any other.The dvd's which do not work(play) are not even
damaged or scrached...its just fine and whenever i insert them in dvd rom it makes odd noise(like its stucking somewhere)
and then nothing happens i.e ITS UNABLE TO READ IT. IF ITS PROBLEM WITH MY DVD ROM DRIVE then why other dvd's and cd's work fine?
Ihave even tried workshop provied in chip (jan 0'6 issue) which says "add zing to your drive" but to no good result.
i dont unstand. why this prob arises only with certain discs while many other do fine even if they are scrached or damaged
while a neat looking DVD'S do not play.(only few of then especially of chip dec'07 and digit dec 0'7)..
ITS GONNA MAKE ME CRAZYYYYY..
PLEASE HELP ME OUT..IF ITS HARDWARE PROB OR SOFTWARE.. AT THE EARLIEST.
THANKS
JIM.
