Old 13-12-2007, 07:49 PM   #1 (permalink)
Proud to be Linux
abhinandh's Avatar
Default hdd headache after upgrade.
guys i upgraded my mobo an proccy to c2d and intel 945.
i have an pata hdd connected to it.the hdd in win xp often makes a sound and stops responding.os hangs.
should i do a bios update????
hdd is workin good with no probs.
http://abhinandh.com
abhinandh is offline
Old 13-12-2007, 08:17 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: hdd headache after upgrade.
have U done fresh installation of XP after upgradation.
ravi_9793 is offline
Old 13-12-2007, 08:50 PM   #3 (permalink)
Proud to be Linux
abhinandh's Avatar
yes.
Old 13-12-2007, 08:55 PM   #4 (permalink)
a_tif's Avatar
i had similar problem
in my case this was a power cable problem,
switching power cables did the trick
hdd made a teeeet noise n then stoped responding
a_tif is offline
Old 14-12-2007, 04:32 AM   #5 (permalink)
Proud to be Linux
abhinandh's Avatar
thanks.will try switching power cables
Old 14-12-2007, 12:41 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
check ur cables\wires ........
... W H O T ...
ax3 is offline
Winxp Setup : Headache wizrulz Software Q&A 4 06-09-2006 09:11 PM
SE W800 headphone Headache Rasper Mobiles and Tablets 4 14-02-2006 11:10 AM
my new moniter (new headache) .... saurya_mishra QnA (read only) 3 07-10-2005 07:38 PM
Problems creating headache Charley QnA (read only) 1 12-06-2005 10:00 PM
amd 64 headache arun CPU / Motherboards 36 07-11-2004 09:39 AM
