Old 12-12-2007, 03:20 PM   #1 (permalink)
Default MOBO Dead...Now what?
Hi all..
i had a amd 64 3000+(939 pin) on a asus a8n-e and a pci-e XFX 6200 (256 MB). recently the mobo has gone dead....(thats another story)....
so now least of all i need to buy a new motherboard.
so should i now go for a motherboard that will support my current proccy and Graphics card.
or
so should i now go for a AM2 motherboard.....i suppose i'll have to buy new ram(ddr2) also cause right now i have a 512 mb 400 mhz DDR module. will i have to change the processor also?
at max i can spare abt 4k.
waiting for your suggestions
regards
manmay
manmay is offline
Old 13-12-2007, 02:49 PM   #2 (permalink)
Default Re: MOBO Dead...Now what?
I think you should be able to manage a motherboard and ram in that budget.
But I think you will have to change the processor also. Socket 939 has been
phased out according to this website :
http://priceguru.in/computer-hardware/amd-motherboards
Maybe if you look around locally you will find some shop having socket 939 motherboards.
Regards
non duality is offline
Old 14-12-2007, 11:07 PM   #3 (permalink)
g_goyal2000's Avatar
Firstly, check whether your mobo has warranty.
If u bought it within 3 years, then it still has 3 years warranty.
If not, u'll probably have to do little searching, but u might find a 939-pin board.
U might also ask a mobo company distributor to order one for u.
I don't think they've stopped making 939-pin boards.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 15-12-2007, 12:12 AM   #4 (permalink)
sounds good....thanks guys for the suggestions
manmay is offline
Old 15-12-2007, 12:24 AM   #5 (permalink)
j1n M@tt's Avatar
If u haf somebody in US, u can buy 939-socket mobo from newegg.com; they haf plenty of dat kinda performance mobos in sale.
Or go for X2 4000+,M2N-MX mobo,1GB DDR2 RAM; will be somewhere around 5K.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
My N80 is dead anandf12000 Mobiles and Tablets 8 03-02-2007 09:51 PM
HDD is dead...Help!!! linardni Hardware Q&A 7 30-08-2006 01:01 PM
hey is my mobo dead pls help!!!!!!!!!!!!!1 Shrex Hardware Q&A 2 30-07-2006 12:32 AM
Is 98 really dead ??????? Help nvidiasingh2006mb QnA (read only) 6 14-02-2006 02:27 PM
Help or i m dead ionicsachin QnA (read only) 6 26-06-2005 03:17 PM
