Old 12-12-2007, 12:16 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Question Is it a problem with my PSU?
My rig:
AMD Athlon 64 3200+ Socket 939(Venice Core)
MSI-RS480M2 motherboard with onboard ATi Radeon Xpress 200G
XFX 8600GT XXX edition
Samsung Samtron 55V 15-inch CRT
Moser Baer DH-20A1P
Samsung Combo drive SM-352B
Vintron Keyboard
Logitech mouse
Sony FDD
Techcom 350W power supply
My problem is, when I'm playing a game, usually the resource hungry ones, after about half an hour or 45 mins, the system hangs and there is no way to come out of it, except for a hardboot. I had planned to buy a 500W power supply in case my system didn't boot when I installed the gfx card. Since it works just fine on no load and on linux with compiz-fusion running, I dropped the idea. The graphics card was installed following the step-by-step instructions given in the manual. So, my onboard ATi was disabled before inserting the card.
One more doubt is, what will happend to the PSU or the other components in case I continue using the same PSU? Though, I have a fair chance that I'll change the PSU, I just want to know. BTW, no computer dealer is ready to take this PSU. So, what will I do with this?
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 12-12-2007, 12:23 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: Is it a problem with my PSU?
Definitely your PSU.
Get Zebronics 500Watt
Harvik780 is offline
Old 12-12-2007, 12:25 PM   #3 (permalink)
phreak0ut's Avatar
How much might it cost? I need to buy the PSU and a couple of games like Crysis(I know it runs at low settings, I don't care ) and COD 4
Old 12-12-2007, 12:27 PM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
500watt normal edition will cost Rs 700.
500 Watt Platinum will cost Rs 1500.
Old 12-12-2007, 12:32 PM   #5 (permalink)
phreak0ut's Avatar
Awesome! I think I can easily afford that. Thanks for the sugggestion Harvik
Old 12-12-2007, 01:05 PM   #6 (permalink)
Google Bot
Pathik's Avatar
^^ Get the Normal one.. we get it for 600 bucks here and works good.
Pathik is offline
Old 12-12-2007, 01:17 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
But Platinum edition worth the price & mental peace
Also Future proff.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 12-12-2007, 06:01 PM   #8 (permalink)
phreak0ut's Avatar
@topgear-I'll be moving to quadcore in around 2 years time. So, I might need a 1KW PSU
BTW, why doesn't the card refuse to work @ 350W though that's the min. required?
Old 12-12-2007, 06:04 PM   #9 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
The PSU is overrated.Most psus in India are overrated.
Old 12-12-2007, 08:47 PM   #10 (permalink)
phreak0ut's Avatar
Guys, please answer my other questions.
Old 12-12-2007, 10:53 PM   #11 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
^^I couldn't get it.
Old 12-12-2007, 11:31 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
It actually gets enough load for small tasks, but as your calculations increase (during games, rendering and such), it fails to acquire additional power (Which even the commanding CPU starts demanding) and panics. This is just my interpretation though.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-12-2007, 12:13 AM   #13 (permalink)
assasin's Avatar
^^^ wat u said is just right.when i bot my 8800GTS i didnt hav a good enuf psu to handle it.so wat i did was to run the gfx card from my Zebby 400w and my system from a HP 250w psu.the system ran ok,but the moment i started to play a game the Zebby 400w psu just blew off.
@phreakOut for ur pc a Zebby 400w wud be enuf.
assasin is offline
Old 13-12-2007, 02:15 AM   #14 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
^^That's because powering the GFX with another PSU does not decrease the power consumption on the 12V rails.
Old 13-12-2007, 10:09 AM   #15 (permalink)
phreak0ut's Avatar
Thanks for the info guys
Old 05-01-2008, 03:35 PM   #16 (permalink)
phreak0ut's Avatar
Hey guys, need help again. I bought 450W PSU, but the problem still exists. COD 4 hangs while playing. One thing I observed is the CPU temperature goes high as 62 C. Is it because of that?
Old 05-01-2008, 04:39 PM   #17 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
can be, do this play the same game with cabinet open and chk if it hangs
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 05-01-2008, 05:36 PM   #18 (permalink)
@phreakOut, I am also facing similar problem... My rig has C2D E4400, XFX n650i Ultra, Leadtek 7600GS gfx, and 2 GB RAM with 500W Zebronics normal SMPS...
Also, once it hangs during a game, the computer continues to crash even when doing regular stuff (sometimes even when logging it)... Only after leaving it for a few days without usage does it get back to normal... Are you facing similar problem too?
Arun
sakumar79 is offline
Old 05-01-2008, 06:08 PM   #19 (permalink)
phreak0ut's Avatar
@zyberboy-My cabinet is open from the day I installed my gfx card. That's not even a month back.
@sakumar-My problem is, if it hangs, that's it. Hardboot is the solution. Once I reboot, there is no problem with other applications.
Old 10-01-2008, 11:09 AM   #20 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Guys u need to update every possible driver and also BIOS if the newer version is available!
This is the common problem that occurs most of the time and most of them are sorted out by the drivers update!
keith_j_snyder2 is offline
Old 10-01-2008, 02:23 PM   #21 (permalink)
phreak0ut's Avatar
I've updated my BIOS and the driver is the one which I got with Digit DVD. It's 163.xx version. Downloading 169 now.
Last edited by phreak0ut; 10-01-2008 at 02:38 PM. Reason: Found latest driver approved WHQL
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
