Old 11-12-2007, 10:26 PM   #1 (permalink)
Thumbs down PC Critical Problem
I have a problem on my pc that my pc automatically power-off after every time well i play some games or when i open a high quality video's. Also when i Whenever i eject a cd and boot from a cd "WinXP" my pc was cut off .
"Jab be main CD dalta hu aur pc restart karta hu to pc apne aap band ho jata he. koi be game khalo yah koi heavy software start karte he to pc band hojata he"
PLease help me, what's the problem was going on here
Motherboard - Asus P5GC-MX
Ram 1GB DDR
SMPS - 450 Watt
G.C - geforce 8400gs
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 11-12-2007, 10:52 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: PC Critical Problem
Kindly give the details of the brand of ur SMPS.
Seems you have the as called local SMPS.Buy a powersafe or zebronics SMPS.
Harvik780 is offline
Old 12-12-2007, 03:29 AM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
The problem is definitely with the smps. I think it is unable to run the 8400 card....... try removing that card n then run using ur onboard video adapter....... if the problem does not persist then its ur SMPS(culprit)!!!!!!
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Critical problems ______ someone please Help the_player Hardware Q&A 12 17-10-2007 09:33 PM
help.....critical problem Raaza QnA (read only) 6 22-09-2005 03:37 PM
Critical problem, Help bukaida QnA (read only) 1 28-07-2005 09:45 PM
Help regarding Windows Critical Updates khattam_ Software Q&A 3 16-04-2005 09:03 AM
Critical Lan Problem superuser Networking 1 26-01-2005 08:25 PM
