If i have to burn a dvd iso of size 4.76 Gb. How do i burn it on a single dvd???? Apart from compressing the dvd image to a smaller size. Please reply . Its kind of urgent...... thanks in advance
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
you can try DVD_shrink provided in this months DIGIT.. and you can also use magic ISO to try and reduce the filesystem size to burn about 4800MB on a disk , but it is dangerous.. i will recommend you to buy a DVD-9 for Rs. 100 (moserbaer) it would be better.
thanks everyone for the suggestions.......
dual layer dvds are not available in my city ........ so cant go in for thst solution....... wil download dvd shrink n see what it can do..........
Sony Vaio CW26FG
