Old 11-12-2007, 05:39 PM   #1 (permalink)
smile's Avatar
Red face Plzzz help needed urgently to upgrade
Hi..............Everyone
My system configuration is :
Intel P4, 2.0GHz processor,
256 MB DDR RAM (266 MHZ),
40 GB HARD DISK (7200 RPM),
GIGABYTE 845 GV MOTHERBOARD,
DVD ROM,
I want to upgrade my system......Can anyone suggest me what all components can be upgraded and supported.....And any changes would u like to share with me will be great helpful to me tp upgrade my system
SR
smile is offline
Old 11-12-2007, 05:43 PM   #2 (permalink)
Default Re: Plzzz help needed urgently to upgrade
Man only your hdd and dvd rom will be usable.You'll have to change all the rest.What's your budget like?
Let there be music.....
sashijoseph is offline
Old 11-12-2007, 05:49 PM   #3 (permalink)
smile's Avatar
For me the budget is around 10-12 k
SR
smile is offline
Old 11-12-2007, 05:52 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
change MOB..and processor ...and RAM
Intel C2D E4500-->> Rs. 5100/-
1 GB RAM-->> kinston, transend Rs 1000/-
motherborad-->>> Asrock intel 945 based..Rs. 2600/-
ravi_9793 is offline
Old 12-12-2007, 12:13 AM   #5 (permalink)
And the HDD is only 40GB and it's only a DVD ROM (not DVD writer) so doesnt help much in retaining those.
@smile, selling off ur system as a whole and getting a new one might make better sense (instead of trying to sell off components, which will be difficult).
BTW ur proccy and mobo are not very bad. Why r u looking to upgrade? If it is to play latest games and stuff, it's fine, else if it's for normal home use, u might be better off getting a 512MB DDR RAM stick.
gulgulumaal is offline
Old 12-12-2007, 11:12 AM   #6 (permalink)
smile's Avatar
Thanks for all those replies ... I would just change my HDD & Ram........Can anyone tell me as am having 845 gv gigabyte motherboard is the board supports latest processor ..is there any way or i need to change the whole board
SR
smile is offline
Old 12-12-2007, 11:21 AM   #7 (permalink)
j1n M@tt's Avatar
I suggest AMD X2 4400+,Asus M2A-VM HDMI m/b(X1250 IGP,far better than Intel 945),1GB Transcend DDR2 RAM.Buy a 250 or 160GB HDD too,40GB is tad too low!!
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 12-12-2007, 12:59 PM   #8 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Dude, churn out some cash and buy 2 GB RAM. Trust me u will not regret buying it!
keith_j_snyder2 is offline
Old 12-12-2007, 02:16 PM   #9 (permalink)
Rebooting
Choto Cheeta's Avatar
@smile
You may refer here Basic Guide Purchase a New System
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Help Needed Urgently kewlashu QnA (read only) 2 27-10-2007 08:29 PM
pls help needed urgently!!!! bhoolkumehul QnA (read only) 7 14-08-2007 04:04 PM
Help needed urgently. 144 QnA (read only) 4 01-02-2007 11:57 PM
needed urgently a.p.vinodh Open Source 5 26-01-2006 11:48 AM
New rig help needed urgently kau_therock QnA (read only) 5 22-06-2005 01:10 PM
