Old 11-12-2007, 12:00 AM   #1 (permalink)
karthik55859's Avatar
Default please suggest the best SLI based motherboard
hello guys,
i am planning to upgrade my system,......
i am looking forward for SLI based mobo....b'coz i planning to gear it up with SLI... SO PLEASE suggest the future proof mobo
i have budget of 12-15k for mobo.....
it should X38 based chipset,it should support ddr3,greater fsb speeds.....2 PCI EXPRESS at full 16X speed
plz plz plz suggest mobo from ASUS,MSI,GIGABYTE....
I AM BIG FAN OF ASUS
i tried searching asus website but, i found maximus formula....but it supports crosslinkx.....plz help i am bit confused
thanking you all
karthik55859
"WHEN GOING GETS TOUGH THE TOUGH GETS GOING"
karthik55859 is offline
Old 11-12-2007, 12:15 AM   #2 (permalink)
Default Re: please suggest the best SLI based motherboard
No need to go for this much Range...
Go for Asus p5n-e sli Mobo...
Check this mobo out n u ll find everythin present here...
Believe me i m using it from last 6 months n its performance is much better than my friend's 14k mobo...
raj.singla is offline
Old 11-12-2007, 12:31 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
x38 and SLI ... hmm.. not sure but I think most of the x38 chipsets coms with CrossFire Support not SLI...
right now the best under SLI may be is P5N32-E SLi / ASUS striker extreme or such and you may have to wait till the 7xx nvidia chipset comes with 3 way and 4 way SLi and DDR-III supports comes to the market
rebooting
ChotoCheeta.com
Choto Cheeta is offline
[Suggest]Debian based Distro for my friend with KDE gary4gar Open Source 11 07-09-2007 02:41 PM
Suggest a motherboard catchjaga CPU / Motherboards 3 11-08-2006 11:45 AM
BEST NFORCE 4 CHIPSET BASED MOTHERBOARD mandar5 CPU / Motherboards 3 25-10-2005 11:29 PM
Most reliable AMD-based motherboard manufacturer in India InclininWirefree CPU / Motherboards 1 19-04-2005 02:15 AM
