09-12-2007, 01:14 PM
AJJU
YIPPE Upgrade :D
hey sorry i created a new thread but i hav less time ...
Gonna Get a new CPU  = MOBO+PROCC+HDD+DVDrive+CAB+RAM
but budget is low as 20k
plz help me guys  waitin
I love and Live to Design
09-12-2007, 01:34 PM
Re: YIPPE Upgrade :D
Intel E6550 @ Rs. 7000 /- + TAX
Intel DG33FBC / DG33BU @ Rs. 5100/- +TAX or Intel G965RY @ Rs. 5000/- +TAX
2 GB DDR-II 800 MHz Transend or Kingstone or ZION @ Rs. 2650 /- + TAX
250 GB SATA-II 16MB Buffer (Segate / SAMSUNG / WD) @ Rs. 2600 /- + TAX
DVD RW Lite-on @ Rs. 1300 /- + TAX
CABINET @ Rs.1500/-
Visit my Blog::::::
http://shyamkol.blogspot.com
09-12-2007, 02:12 PM
AJJU
thx for Quick reply bro...
shud i go for the intel mobo ??
how about XFX ?? and any basic Gfx cards?
bmp
Reason: Automerged Doublepost
09-12-2007, 02:24 PM
Google Bot
I wd get a
e4500 -4.8k
xfx 8600 gt 256mb gddr3 udf7- 5.8k
seagate 250 gb sata 2 7200.10 - 2.4k
2*1 gb ddr2 667 mhz ram- 2k
Normal atx cabby + 500 w psu - 2k
Sony dru 835a - 1.5k
Biostar p35- 3.5k
09-12-2007, 02:57 PM
the config posted by pathiks is good.but i'll suggest u to get the XFX 650i instead of the Biostar P35.
09-12-2007, 03:26 PM
AJJU
iam thinkin
Intel DG33FBC
2 GB DDR-II
DVD RW Lite-on
does XFx 650i hav onboard gfx ??
iam not a big gamer but wud like to play and i will run Vista..
wat's the diff between Intel DG33FBC and DG33BU
plz help me guys let me get the Best..
ELP
09-12-2007, 03:45 PM
die blizzard die! D3?
xfx650i has no onboad graphics.
I would suggest:
e4500 -4.8k
xfx 650i-4.6k
Seagate 250gb hdd--2.5k
2x1gb ddr2 667mhz RAM-2k
DVD-RW Lite-on 20AIP--1.2-1.3k
A cheap large cabby---1k
Zebronics platinum 500watt PSU--1.5k
xfx 8400gs---2.5k(since you said you are not a serious gamer).
Stealing your women and horses since 1843.
09-12-2007, 04:42 PM
AJJU
Y not a Intel E6550 and
Intel DG33FBC ?? y ? plz tell me
BUmping..
09-12-2007, 04:44 PM
Google the Term and you will get direct links to the Mobo Specs Sheet
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
09-12-2007, 05:48 PM
AJJU
^^ i did but didnt help much ....
iam goin with the my conf in 6th post is it ok ?? guys help me
09-12-2007, 05:53 PM
Pharmaguru
I am taking sameconfig with mainboard is DG33FB
yes please suggest both of us ...
my budget is 20K without DVDwriter though, but taking 320gb HDD
*Ok i found out diff. One is ATX (BFC) and other is microATX(BU) hence no. of PCI slots and PCIe 1X are limited to 1 on DG33BU
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
09-12-2007, 05:57 PM
AJJU
^^ ya plz suggest both of us
just googled for gigabyte GA-G33M-S2H looks like its a great mobo
plz guys elp us
09-12-2007, 06:12 PM
Google Bot
1. Depends on whether u ll OC or not.
2. x3100 sucks if u r a gamer.
3. Rather get a cheap p35 board or a 650i board and a cheap gfx card.
09-12-2007, 06:29 PM
AJJU
^^ i didnt oc'ed till now
and confused still ..... tell me y not e6550 and y e4500 ?
and how about giga byte ..GA-G33M-S2H
ill take a Second Gfx card later.
09-12-2007, 06:30 PM
Pharmaguru
I am will not OC my Pc and i am not a gamer. but will play some old games like HL2 or San Andreas at Low setting. (will they ruN?
09-12-2007, 06:35 PM
AJJU
^ they will kjuvale and even Nfs ug 2 ??
so looks like this is deal
e4500 -4.8k
xfx 650i-4.6k
xfx 8400gs---2.5k
but still wat about GIGAbyte GA-G33M-S2H
09-12-2007, 08:56 PM
^^close your eyes and get this.
forget g33 and all.Either get xfx 650i or abit-IP35-E
ABIT IP35-E
LGA 775
Intel® P35
FSB 1333
Dual DDR2 800
PCI-E X16
SATA 3G
Gigabit LAN
7.1 CH HD Audio
RoHS Compliancy
CPU Support Intel® Core™ 2 Extreme/Duo/Quad processors with 1333/1066/800MHz FSB
Support Intel® Core™ 2 Extreme/Quad/Duo & Pentium® Dual Core Processors
Chipset Intel® P35 Express / ICH9R Chipset
Memory 4 X 240-pin DIMM sockets support max. memory capacity 8GB
Supports Dual channel DDR2 1066/800/667 Un-buffered Non-ECC memory
LAN On board Dual Gigabit LAN controller supports 10/100/1000M Ethernet
Audio On board 7.1 CH HD Audio CODEC
Supports auto jack sensing and optical S/PDIF In/Out
HDMI ready header (SPDIF header)
Expansion Slots 1 x PCI-E X16, 1 x PCI-E X16 (x4 bandwidth), 1 x PCI-E X1, 3 x PCI
Internal I/O 1 x Floppy Port supports up to 2.88 MB
1 x ATA 133/100/66/3 IDE connector
6 x SATA 3Gb/s connector
2 x IEEE1394, 3 x USB header (support 6 ports)
1 x FP-Audio
Back Panel I/O 1 x PS/2 Keyboard, 1 x PS/2 Mouse
abit Silent OTES™
1 x S/P DIF In, 1 x S/P DIF Out
2 x eSATA
7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
4 x USB 2.0
1 x RJ-45 LAN connector
EZ CCMOS Switch
Serial ATA 6 x SATA 3Gb/s offer by Intel® ICH9R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10)
2 x eSATA 3Gb/s through JMicron® JMB363 support 0,1JBOD RAID function
IEEE 1394 Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate.
Form Factor ATX form factor 305 x 245mm
PCB Color: Blue
RoHS 100% lead-free process and RoHS compliant
abit Engineered abit µGuru™ Technology
abit Silent OTES™ Technology
100% Japanese made Low ESR and high ripple conductive polymer aluminum solid state capacitor
100% Japanese Capacitor
EZ for CCMOS
09-12-2007, 09:00 PM
AJJU
devil it sounds kool  can i know the Cost ?
09-12-2007, 09:01 PM
#19 (permalink)
oh forgot,its around 6.5k.
10-12-2007, 05:52 PM
#20 (permalink)
AJJU
Finilising this
intel Q6600
Intel DG33FBC
2 GB DDR-II
DVD RW Lite-on
shud i go for intel mobo or Gigabyte ?? plz help me
waiting
10-12-2007, 06:02 PM
#21 (permalink)
dont buy Intel cuz u wont hav any oc options.so buy a Asus/Gigabyte G33 based mobo
10-12-2007, 06:10 PM
#22 (permalink)
AJJU
this one
now wat cud the total cost sum me up ?
intel Q6600
2 GB DDR-II
DVD RW Lite-on
10-12-2007, 06:12 PM
#23 (permalink)
^^too high to fit in your 20k!!
q6600 alone costs 11k+taxes.
10-12-2007, 06:26 PM
#24 (permalink)
AJJU
^^ it wud be high but wat do u think the cost wud ??
ready to Xtend sum budget
btw:do Quad's hav great perfomance tha 2Dual core's ?
10-12-2007, 06:32 PM
#25 (permalink)
2 dual cores are no match to quad core.
and about costs?add up yourself,you know the cost of individual items already.
If I were you I would have gone for a e4500 and a low end graphic card than for q6600.Most games\applications are graphic intensive rather than cpu intensive.Haven't seen many apps\games make use of even 80% of my c2d.
10-12-2007, 06:42 PM
#26 (permalink)
AJJU
an sorry my mistake i meant wat is high perfomance boost compared to core2duo  he he my mistake
Brw: iam plannin to get a 5k gfx card in5-6 months so will be on Onboard for few months that's it
so its 18 k without mobo wats the MOBO cost ???
still confused weather to take Gigabyte g33 mobo or other
10-12-2007, 06:54 PM
#27 (permalink)
Q6600 wud be awesome.
get gigabyte coz u cant OC on intel mobos.
or if u can,then get nvidia 650i mobo-4500rs.
10-12-2007, 07:02 PM
#28 (permalink)
AJJU
^^ is it with onboard gfx ?? but features r lower than gigabyte and ya cost too lower  any other good mobo's ??
mention with cost plz..
10-12-2007, 07:04 PM
#29 (permalink)
you'll need a very good mobo to match the raw power of q6600.Get the newest x38 chipset based mobos.
ABIT-IX38 quad gt----13k or something.
#30 (permalink)
nvidia 650i is gr8.
get it.its under 5k
@devil-his budget is 20k and this mobo and q6600 will make a sum total of 24k alone.
bachche ki jaan loge kya?
