Old 09-12-2007, 11:52 AM   #1 (permalink)
AFK
thewisecrab's Avatar
Default xternal hdd not detected
Hi Guyz (sorry if wrong section)
My Internal HDD (samsung spinpoint) was converted to external hdd with usb2.0 and casing
I installed sum soft (chord pickout 4 guitar) after plugging it to my system
and unplugged it without any prob
I also installed my hp printer driver + soft the same day after unplugging d xternal hdd
since then XP has not detected this hdd even after plugging in
it doesnt autorun
also when i click on the icon of Hdd in my Computer, my pc hangs 4 a while and then says
"<drive letter> is inaccesible. error performing inpage operation"
The device is shown on "safely remove device" after pluging it in.
but i cant stop it as it says another prog is accesing the device (task manager doesnt show xtra process)
also when i plug it in when windows boots, it halts in the welcome screen 4 'bout 5 min and
then says
"windows has recovered from a serious issue"
and goes ahead as usual without detecting the device
i really need the device
what d hell is wrong???????????
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 09-12-2007, 12:12 PM   #2 (permalink)
Default Re: xternal hdd not detected
Does it work on another computer?
ThinkFree is offline
Old 17-12-2007, 05:43 PM   #3 (permalink)
AFK
yup... although it says error and new hardware might not work
its working fine (tried on lappy)
Dvd Rom Does Not Gets Detected ::vicky:: Hardware Q&A 7 02-05-2007 12:10 PM
HDD not detected plsoft Hardware Q&A 6 25-04-2007 11:11 AM
HDD not detected sometimes pushkaraj Hardware Q&A 4 23-02-2007 08:07 PM
WD 80 gb ata hdd not detected by RH9 choudang Open Source 3 27-08-2006 10:53 AM
HDD not detected rahul_becks23 Hardware Q&A 7 25-07-2006 09:37 PM
