Old 08-12-2007, 09:18 PM   #1 (permalink)
Default How to check HDMI version?
Hi Guys,
If you gonna buy HDTV in INDIA..the user manual doesnt specify which HDMI it has HDMI 1.2 or HDMI 1.3b and so on...
Now is their any test by which we can know which type of HDMI , the product has ?
chits is offline
Old 10-12-2007, 08:32 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: How to check HDMI version?
its just... hdmi ... just go with it it works..
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 10-12-2007, 09:51 PM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
hmmmm.................there are different versions of HDMI ( just like USB 1.1 and USB 2) for sure but most of the manufacturers do not specify the version.Later versions do cater for higher bandwidth but I do not know the real significance-needs some digging.
And yes, here is some bit of info from www.hdmi.org
Q. What functionality was added to each specification?
The following provides an overview of major functionality added to each version of HDMI:
HDMI 1.1
  • Support for DVD Audio
HDMI 1.2
  • Adds features and capabilities that increase HDMI's appeal for use in both the CE and PC industries. Specifically, the features and modifications for HDMI 1.2 include:
    • Support for One Bit Audio format, such as SuperAudio CD's DSD (Direct Stream Digital)
    • Changes to offer better support for current and future PCs with HDMI outputs, including:
      • Availability of the widely-used HDMI Type A connector for PC sources and displays with full support for PC video formats
      • Ability for PC sources to use their native RGB color space while retaining the option to support the YCbCr CE color space
      • Requirement for HDMI 1.2 and later displays to support future low-voltage (i.e., AC-coupled) sources, such as those based on PCI Express I/O technology
HDMI 1.2a
  • Consumer Electronic Control (CEC) features and command sets and CEC compliance tests are now fully specified.
  • Creation of version 1.2a of the HDMI Compliance Test Specification (CTS), which includes a CEC Supplement. HDMI CTS 1.2a has been updated for technical consistency with HDMI Specification 1.2a as well as to the recently released HDMI Specification 1.2.
  • Significantly, CTS 1.2a contains additional cable and connector testing and Authorized Testing Center (ATC) submission requirements. Specifically, under CTS 1.2a, the Adopter shall submit for testing to the ATC any new HDMI cable whose length exceeds previously tested cables.
  • Additionally, HDMI Licensing, LLC will maintain a list of approved connectors. For a device to pass CTS 1.2a testing at an ATC, all connectors on such device must appear on the approved connector list. To add a connector to this list, the vendor must submit to the ATC or HDMI Licensing, LLC full and passing testing results.
Q. What has been added in the HDMI 1.3 specification?
Please see the HDMI 1.3 section at
http://www.hdmi.org/learningcenter/faq.aspx
Ponmayilal is offline
Old 11-12-2007, 01:31 PM   #4 (permalink)
HDMI 1.3..consists of HDMI 1.3a and HDMI 1.3b..
Advantages are ..
spee of 10.2 Gbps
supports more colors upto 48 bits ....
a new color space xvYCC
Dolby True HD format in which raw PCM will be sent for every channel...
except for audio ,HDMI 1.3 has no major use...for video the source has to contains information...
check this
http://www.engadgethd.com/2006/10/13...-for-hdmi-1-3/
Sony V-series LCD TV does advertise with "Wide Color Gamut"....is this 1.3 ?
Gamut = Subset of color...
chits is offline
World’s first: Quad-port HDMI chip from Fujitsu ArZuNeOs Technology News 2 03-12-2007 06:40 AM
Wireless HDMI On the Way iMav Technology News 2 28-08-2007 07:48 PM
M2AVM-HDMI need experts opinion gksunil Hardware Q&A 11 21-04-2007 12:01 PM
Black Xbox 360 With HDMI, 120GB HDD Shown in Gaming Magazine iMav Technology News 1 22-03-2007 12:02 AM
