Old 08-12-2007, 03:36 PM   #1 (permalink)
Default Upgrading My Very Old system - Experts Please Help Me Out
Hi guys,
Iam Planning to upgrade my old system im my office. It is very old... Think its p1...
In our office there are 2 system:
1-> Server: Its an old p1 based system. It stores all our Companies a/c... Very important datas...(dos based)
2-> Client : It is also an old system. it is connected to server by an old model lan card (Picture attached). On it startup it will ask whether it should start with lan. If "y" given it will start in dos mode(for accounts purpose). If "n" given it will start windows98 (which is installed in system itself)...
Now i wanna update System2 (client). I hav few que regarding it...
1. Is it possible to install thiese old type of lan card in latest system???
as it doesn't fit pci slot(its huge). If so the problem ends here. Any other way???
2. Is it possible to install the hdd of the server to the new machine??? So tat the comp cud work without server. My service man tells tat the hdd in the server is very old n it cannot be installed in new systems...
3. Is it possible to backup the hdd of the server to new hdd n install it in new system???
4. is it possible to upgrade the server itself??? so tat the client can be easily upgraded...
5. Is it possible 2 install new model lan card in the server??? As the client already has new model lan card... if so how 2 install driver?? as its dos based n it doesn't hav any cd r floppy drive
Please help me out... Now iam in critical situation tat i sud upgrade my system for other office purpose...
Thanks in advance
Regards,
Navin.
navino87 is offline
Old 08-12-2007, 10:53 PM   #2 (permalink)
Default Re: Upgrading My Very Old system - Experts Please Help Me Out
Some 1 please help me out...
navino87 is offline
Old 08-12-2007, 11:20 PM   #3 (permalink)
1. The card u have is not PCI, it's ISA. It's very old standard. U wont find ISA slots on any of the newer motherboards (ISA has been obsolete for the past 10 years atleast). So pretty much u cant use the card
2. If the HDD is IDE, then yes, you can use it on any motherboard. Just attach a snap of the HDD connector and cable, and I'll tell u if it's IDE.
3.If it's IDE, u can backup and copy.
4.I have no clue. Not enough details.
5.If server has PCI slot u can install new model LAN card. Even in DOS mode, u can install the drivers.
U r asking too many questions without giving details
BTW how r the client and server connected? Is it using normal ethernet cable?. The connector on ur LAN card looks very wierd. Is it using coaxial cable or something?
gulgulumaal is offline
Old 08-12-2007, 11:53 PM   #4 (permalink)
^^^ thanks for ur reply... n sorry for less details...
Lan card: ISA-Bus Ethernet Adapter with BNC connectors.
A 1990s Ethernet network interface controller card which connects to the motherboard via the now-obsolete ISA bus.
Exact image : http://upload.wikimedia.org/wikipedi...twork_card.jpg
now-obsolete ISA bus: http://en.wikipedia.org/wiki/Industr...d_Architecture
Image: http://upload.wikimedia.org/wikipedi.../3/36/Isa1.jpg
Exactly wat i wanna know is is there a pci card with BNC connectors...
I will check whether the hdd is ide n tell later... as now iam at home...
I cant give more info because its very old tat i cannot understand anything...
navino87 is offline
Old 09-12-2007, 12:00 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
The HDD should be EIDE. This standard has been existant since about more than 10 years now!
infra_red_dude is offline
Old 09-12-2007, 12:06 AM   #6 (permalink)
so now wats the way 2 upgrade my office system??? another que, is it possible to connect 2 comp to 1 monitor???
navino87 is offline
Old 09-12-2007, 12:57 AM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
Yes its possible using a KVM Switch ..
Charan is online now
Old 09-12-2007, 03:17 PM   #8 (permalink)
Thanks a lot for ur valuable reply guys.... Today i explored my server... It has 3 pci slot, think the hdd connected 2 it is ide but not sure of it... i took tat hdd n connected it to my new system... it worked fine it started up with tis hdd... every thing gone fine. when the server started it said some error with memory... (i hav 1 gb ram in my new comp) another error msg tat network cable unplugged. then started up normally...
Think tis info is sufficient... If more info required please ask me guys...
Now please help me out for my upgradation guys...
navino87 is offline
Old 09-12-2007, 09:07 PM   #9 (permalink)
^^^My understanding is that u want to upgrade both ur machines (client and server).
Things that are holding u back are
1. Whether u can connect/get data from ur HDD. I think that problem is solved now, since u r able to connect it to ur new system
2. Connecting ur client to ur server.
Am I correct?
I suggest u check the following
See if u can connect ur client to server using ethernet cable instead of BNC. If that is possible, it shud be easy to upgrade both machines. After upgrade u shud be able to use the onboard ethernet connectors to connect the machines.
If u have to go with BNC connectors, check with some computer stores whether ethernet cards with BNC connectors are available. I dunno if these are available.
Check this out
http://en.wikipedia.org/wiki/10BASE2
Old 09-12-2007, 09:51 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I suggest you conect the HDD to a new system(not DOS) and copy all files from it to a new HDD. such an old system having critical files is a bad idea
edit: sorry, I mistead your point. I see that you WANT to upgrade the system. still, my tip holds good. I advice you to make a backup of the HDD and ditch the old one. Use a SATA II disc this time.
you may try an external case for coppying the files from.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 10-12-2007, 01:24 AM   #11 (permalink)
Thanks a lot for ur suggestions guys....
Now the thing is tat When i connect the servers hdd as Master hdd in my new sys it starts up as server... When i connect the servers hdd as slave hdd in my new sys it it does't starts up with my new hdd... i get some error ...
Another thing is tat now i dont want tis server client system... i wanna make it in to a same system... But data1, data2 are 2 drives which has all our datas... but tis can only be assessed in the client when the server in loaded... I cant even see tis 2 folders in the server when it exits to dos mode... n when server is loaded i get "DPL:" instead of "c: or d:" i cant give any command in the server except "down"(tis will down the server mode n enter in to dos mode... n when the server in down the client cannot access server files data1 n data2) n in dos mode there is no data tat is relevant to our company...
1.now how can i access server's hdd in windows xp (new system) so tat i can take backup...
2.If the hdd is accessed in windows xp then where can i find data1 n data2???
I am mush confused now... Now i am pushed to the situation to upgrade my office system for other office purpose except accounts...
Please help me out guys...
navino87 is offline
Old 11-12-2007, 09:42 PM   #12 (permalink)
Y dont u reply guys???? Is the info provided not sufficient??? please help me guys....
navino87 is offline
Old 12-12-2007, 12:04 AM   #13 (permalink)
^^^dude...seriously...ur problems are too complex to discuss this way on a forum. U need some expert help...get the service of some knowledgeable computer guys in ur city. Since it is for your office, I suppose u wouldn't mind paying for service.
Old 12-12-2007, 06:25 PM   #14 (permalink)
really i dont mind paying for tis... but the fact is tat none i met has knowledge in tis...
navino87 is offline
Old 12-12-2007, 06:43 PM   #15 (permalink)
g_goyal2000's Avatar
I totally agree with him. But if u can't find someone who's able to help, then would be better if u bought an entirely new system.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 12-12-2007, 06:45 PM   #16 (permalink)
101101
Why are you spending time waiting for others to reply to help you out with ur upgradation...Better go and buy a new system itself.
Finding answers is simple, all you need to do is come up with the correct questions.
crystal_pup is offline
Nokia Experts... Please Help! He28 Mobiles and Tablets 6 14-07-2007 03:28 PM
Need help - upgrading system silkyboy Hardware Q&A 3 05-06-2007 08:16 AM
Experts Help Needed !! p900 Software Q&A 6 09-05-2007 09:59 AM
Any SMF Experts , HELP ! Charley Software Q&A 3 20-08-2006 10:26 PM
Want to know the prices for upgrading the system vps85 QnA (read only) 2 17-01-2005 11:57 AM
