Old 08-12-2007, 12:28 AM   #1 (permalink)
Arun the Gr8's Avatar
Question Help Me With D Grraaaaaphics Card
my comp config is:
AMD Athlon 64 3000+
MSI RS482M2-IL Motherboard
512 MB DDR 400 MHz RAM
80 GB SATA 7200 RPM HDD
I want 2 upgrade my pc so that i can run windows vista and the new directx 10 based games.
I have decided to go for an additional 1 GB of RAM and a graphics card based on the upcoming nVidid 9500 DX 10.1 card from nVidia. i have time till feb 2008.
wht my query is that will my CPU & RAM bottleneck my GPU; bcoz they r 2 yrs old. should i buy a lower end card to get d best. it is now a days written in Digit dat now a days all d graphics work is routed 2 d GPU n d CPU has lttle work 2 do. is it true???
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 08-12-2007, 12:39 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Help Me With D Grraaaaaphics Card
May be you have missed this one
Graphics Cards related queries here.
the sticky is there to address all GRFX card related question
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-12-2007, 12:40 AM   #3 (permalink)
j1n M@tt's Avatar
Exclamation Re: Help Me With D Grraaaaaphics Card
yeah, its ture u don't have to worry much about ur CPU.....
who told u nVidia is going to have DX 10.1 cards???
Its ATi coming up with DX 10.1
tell whats ur budget? so dat a G card can be suggested
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 08-12-2007, 01:40 AM   #4 (permalink)
assasin's Avatar
ur proccy is surely going to be a bottleneck.since ur going to wait till Feb for the 9xxx series cards better upgrade ur proccy to C2D or something like that now.
assasin is offline
Old 08-12-2007, 11:31 PM   #5 (permalink)
well if i don't want 2 upgrade my mobo n processor bcoz i need d upgrade 4 a short term... then wht shouldi go 4... my budget is around $150... yeah, i will get it imported ... by an uncle of mine.. they r very cheap out there...
Old 08-12-2007, 11:42 PM   #6 (permalink)
Google Bot
Pathik's Avatar
in 150$ u ll only get the 8600gt or maybe the ati hd 3800+
Pathik is offline
Old 09-12-2007, 12:41 AM   #7 (permalink)
dOm1naTOr's Avatar
Yup, u can get HD 3850 for 150$ from newegg
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-12-2007, 08:42 AM   #8 (permalink)
i actually want it just 4 d while so wht i m askin is dat if i buy an ati 3850 (i know dat it 2o is dx 10.1 based) will it work with my cpu without being bottlenecked
i also wanted 2 know dat since my processor is amd based, my mobo chipset is amd/ati based... so wil it give me any performance gain 2 buy an ati gpu??
Old 09-12-2007, 09:06 AM   #9 (permalink)
Cant say about that but nVidia Chipsets + nVidia Gfx perform better with each other.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 09-12-2007, 09:41 AM   #10 (permalink)
dOm1naTOr's Avatar
@Arun the Gr8
yup, ATI cards with ATI chipset worx gr8.
There are some xtra features like, u can use the onboard DVI/D sub also alomg with those in card. This time display is controlled by card. And many more.
G3: XPS M1530 |
FZ 16.
Old 09-12-2007, 04:57 PM   #11 (permalink)
Originally Posted by aravind_n20
@Arun the Gr8
r u talkin' abt dat multiple monitor thing??
Old 09-12-2007, 08:55 PM   #12 (permalink)
dOm1naTOr's Avatar
yup. And there is aslo some extra motherboard chipset compatible modes.
G3: XPS M1530 |
FZ 16.
Old 15-12-2007, 11:35 PM   #13 (permalink)
Question Re: Help Me With D Grraaaaaphics Card
What kind of... gimme som egs..
Old 16-12-2007, 12:23 AM   #14 (permalink)
dOm1naTOr's Avatar
In riva tuner, u can enable mobo chipset compatibility mode. It reduces crashes due to overclocking d also boasts of performance boost
G3: XPS M1530 |
FZ 16.
ExpressCard - Data Card and TV Tuner Card hailgautam Software Q&A 1 20-10-2006 12:30 AM
Tv tuner card / Graphics card for my config ... gsenthil PC Components / Configurations 4 08-09-2006 07:23 PM
graphic card or T.V card for video capture on harddish jagdish18 Software Q&A 2 08-12-2005 02:31 AM
Query Reg Graphics card/TV Tuner card tiwariG QnA (read only) 10 10-09-2004 06:38 PM
