Old 07-12-2007, 04:40 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Question external DVD writer USB ?
HI ALL
As my laptop and desktop DVD writers keep on showing errors ..i was thinking the idea of buying DVD writer (external USB based) .. can anyone tell me how successful are they ? and whats the cost (cheapest) ..
and also tell your exp abt USB external CD writers ..
TIA
Sumit
esumitkumar is offline
Old 07-12-2007, 04:57 PM   #2 (permalink)
royal's Avatar
Wink Re: external DVD writer USB ?
Well I have been using my BENQ1650 internal DVD writer as an external one with a IDE to USB connector cable for quite sometime now.
I connect it to my laptop and have burned over 200 DVDs so if you have an internal writer u can convert it to an external one.
royal is offline
Old 07-12-2007, 05:40 PM   #3 (permalink)
Call me Sumit
Default Re: external DVD writer USB ?
^^ hows that possible
Old 07-12-2007, 05:56 PM   #4 (permalink)
Deadman Walking
Batistabomb's Avatar
Sony 18 x Ext. Rs. 5800/-
LG 18X Ext. Rs. 3480/-
Sony Slim DVD Writer Rs. 6050/-
Iomega external DVD writer compact version is available and preffered one...but do not have the pricing off hand...
If you are little adventures and want to save money, then you can buy a external casing available for Rs.800/- and plug in a internal DVD /combo drive for it...but then i have heard problems related to it and might require tweaking....for some drives...
HP DVD420e and it works great.
Make sure that whatever DVD writer you buy, it should be able to burn the format you need, eg, DVD+ or DVD- and now the latest is the blueray or HD
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 07-12-2007, 06:40 PM   #5 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^damn costly man!
I think it would be better to get a simple internal dvd wtoter and get a sata\ide to usb something.Spending 5k on dvd writer sounds too much IMO.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 08-12-2007, 05:02 AM   #6 (permalink)
Call me Sumit
^^ is that casing same which is used for connecting PATA HDD to connect it to USB ?
Old 08-12-2007, 11:08 AM   #7 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
normal ide writer and a case for it will come at rs 2000. by normal, I mean liteon 18x(22x a bit costlier)
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 08-12-2007, 11:08 PM   #8 (permalink)
royal's Avatar
like this
royal is offline
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
External HDD whizkrive Hardware Q&A 4 16-07-2006 10:48 PM
USB external DVD RW+/- a_medico Hardware Q&A 8 14-02-2006 06:06 PM
suggest external dvd-writer! .:;AddICtEd;:. Hardware Q&A 4 09-01-2006 03:17 PM
