Old 07-12-2007, 01:11 PM   #1 (permalink)
GeekyBoy's Avatar
Default Buying a Motherboard....
My friend is buying a Motherboard+RAM+processor this december. What is the best combo he can find within Rs 10000? (He is going to use onboard graphics, so it should be good.)
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 07-12-2007, 01:15 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Buying a Motherboard....
Asus m2a vm hdmi
amd x2 5200+
@*1gb ddr2 667 mhz ram.
Pathik is offline
Old 07-12-2007, 01:16 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
welcome back long time no hi
may be you have missed this this
Basic Guide Purchase a New System
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-12-2007, 11:51 PM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
very true...its a perfect guide for people who want to but hardware right now
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 08-12-2007, 08:59 AM   #5 (permalink)
premsharma's Avatar
I think you should upgrade this guide, since then lot has happened
premsharma is offline
Old 08-12-2007, 11:14 AM   #6 (permalink)
GeekyBoy's Avatar
In this thread(http://www.thinkdigit.com/forum/showthread.php?t=71700), people seem to overlook what I requested, so please answer my queries in this thread.
My query was:
GeekyBoy is offline
Old 08-12-2007, 12:40 PM   #7 (permalink)
Jus visit the link provided above. u can very well get all the rates n the possible combination ur friend can think about..... have a happy time shopping
Sony Vaio CW26FG
Old 08-12-2007, 05:44 PM   #8 (permalink)
Rebooting
thnx for the tip, but did u paied a visit to the last pages of the Thread ?? usually members do try and help out if some one posts a certain budget and needs to suggest the most up2date config !!!
I am not a paid employee so updating the thread is not my JOB its just a voluntary effort which i put when I get some free time to spend on this forum... so yes I try my level best to keep all information which I have provided up2date but then again time is a mojor factor so, its once a 40 or 45 days the thread 1st post would go through a mojor update
rebooting
ChotoCheeta.com
Buying a motherboard Cool Buddy CPU / Motherboards 3 22-11-2007 03:26 PM
Need Help in Buying a new Motherboard!!! keith_j_snyder2 Hardware Q&A 3 31-12-2006 11:15 PM
Help needed for buying motherboard, Processor and RAM montylee Hardware Q&A 6 07-11-2005 09:27 AM
Buying a New PC!!!!!!!!! Delta QnA (read only) 20 29-04-2005 08:46 PM
