Old 06-12-2007, 10:17 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Smile Need Help regarding HDD
If i have to merge different partitions or modify the size of partitions without losing the data stored in the hdd, which software should i use??????
it should be a freeware and should do the job nicely
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 06-12-2007, 10:38 PM   #2 (permalink)
j1n M@tt's Avatar
Thumbs up Re: Need Help regarding HDD
Try using Magic Partition......
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 06-12-2007, 10:39 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: Need Help regarding HDD
Paragon Partition Manager
PowerQuest Partition Magic
Pathik is offline
Old 06-12-2007, 11:24 PM   #4 (permalink)
is paragon partition manager a freeware?????
Sony Vaio CW26FG
Old 06-12-2007, 11:25 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
@codename_romeo
To be honest, if you have a valuable data, then backup fully before even u think of playing with the partition table
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-12-2007, 11:28 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ +1. Never trust any software regarding this issue. You can try GPartEd (Free), or partition manager/magic or magic partition.
infra_red_dude is offline
Old 06-12-2007, 11:29 PM   #7 (permalink)
Originally Posted by Choto Cheeta
@codename_romeo
thanks for the valuable advice man..... even i fear trusting some software wid my data............
Sony Vaio CW26FG
