Old 06-12-2007, 11:43 AM   #1 (permalink)
Question usb write protected
hello everyone .........
im using "Transcend JF v30 /2GB" flash drive.I bought it 3 months ago.
when im trying to open now it tells me to format.......
when i try to format it .....it says "This Disk is write protected"
then i tried manually by right click the disk it showsthe same message..
when i asked a friend he said that there will be a small lock present on hardware of my usb.But i cant recognise whre its present....
please give me a solution for this....
if ther is any lock please give me a screenshot of hardware......
Thank u all and i hope ill get a solution to it
thanks in advance......................
smslca is offline
Old 06-12-2007, 11:52 AM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: usb write protected
Just log in there web-site n tell them ur problem,After verifying the desired code,they will surely help u SIMPLE!
Hope 4 d best n Do d right :)
reddick is offline
Old 06-12-2007, 12:01 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
@smslca, there's no manual/mech. lock in this pen drive.
its present on memory cards (SD/ memory stick...).
did u accidently put p/w lock (PC lock) or something... using the Transcend s/w? (JFSW)
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 06-12-2007, 09:38 PM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
probably u used some software on the pen drive....please give details
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 07-12-2007, 06:37 PM   #5 (permalink)
troubleshooter
bluepearl's Avatar
check this by Vishal Gupta
http://www.askvg.com/all-kinds-of-re...003-and-vista/
check the registry entry for USB write protection
no.15 restriction
bluepearl is offline
mmc write protected shidhin4ever Mobiles and Tablets 5 26-11-2006 09:45 AM
Drive is write protected Ablenwill Mobiles and Tablets 4 11-12-2005 05:53 PM
how to make a CD write protected????? dittualex QnA (read only) 9 15-11-2005 05:48 PM
how to create write protected vcd gaju6696 QnA (read only) 1 29-10-2005 04:56 PM
how do i delete a write protected file? hbk88in QnA (read only) 4 07-01-2005 10:35 PM
