Old 04-12-2007, 01:20 PM   #1 (permalink)
Default boot/bios screen filled with characters
I have a relative who is using an ancient system with the following specs
It is LG branded PC.
Motherboard is gigabyte 81845 gvm-rz (it is shown on the motherboard)
In short,
According to him, he has downloaded some songs and then windows xp crashes.
Now when the PC is started, in the boot screen which usually display cpu and ram info..the words are not displayed clearly and looks distorted and difficult to read
something about default cmos loaded.
below, there is f1 or f2(cant read clearly) to continue, del to enter bios and others...etc
when i press f1, it simply display a screen filled with exclamation mark (!) and a few other characters
Windows xp however failed to load and i get stuck at that screen
Even the bios setup screen is filled with all kinds of characters and cant read anything that is meaningful on screen..however actually it is working as i can naviigate using the arrow key and could save or exit the bios.
have checked 2 ddr400ram by inserting it one at a time..
have removed the cmos battery and then put it back after sometime
found the cmos clear and removed the connector or whatever it is called and then put it back
again found one with the BIOS something, removed it and then connect it back
still no progress
since i didnt test with a known working stick of memory..so the memory problem couldnt be ruled out yet.
but could it be a graphic related problem and it uses integrated graphics with no agp or pci slot in sight
or could it possibly be a bios corruption or other related stuff
i havent seen such a problem before so please enlighten me on the matter
thank you for reading this far
realdan is offline
Old 04-12-2007, 08:03 PM   #2 (permalink)
Default Re: boot/bios screen filled with characters
Generally it's the ram.Try with a friend's working stick just to confirm.
Let there be music.....
sashijoseph is offline
Old 04-12-2007, 08:47 PM   #3 (permalink)
well thank you for the reminder
will get to his place with a ddr400 ram that i have lying around unuse...will post the result again
realdan is offline
BIOS boot up problem vinodxx Software Q&A 4 03-08-2007 02:23 PM
boot problem with BIOS demoninside9 Hardware Q&A 7 22-07-2007 07:36 AM
BIOS Screen ! :D BBThumbHealer QnA (read only) 11 04-06-2007 09:01 PM
Boot screen help codename_romeo Software Q&A 7 23-11-2006 01:40 AM
NEED HELP!! pc WON'T boot, No bios access, SIREN like noise rage_666 Hardware Q&A 8 27-01-2006 03:48 PM
