Old 02-12-2007, 12:52 PM   #1 (permalink)
Default unclear sound
i recently bought an altec lansing ATP3 speaker system.i am using an intex soundcard(300 bucks) .however the sound is not very clear.there is quite a lot of disturbance.but when i coonect my speakers to my mp3 player,theres no problem.so should i change my soundcard.if so which soundcard should i buy.(a low end)
Thanks
raviramgopal is offline
Old 02-12-2007, 03:01 PM   #2 (permalink)
Default Re: unclear sound
I probably think that the Hiss sound or disturbance is mostly due to the cheap soundcard.
I suggest you to go for any of the following soundcards depending on your budget.
(Prices in Bangalore -> may be +/- 200/300 bucks)
Creative 5.1 - Rs. 1060
Creative 7.1 Audigy - Rs. 1600
My recommendation is to go for the Creative 7.1 Audigy which would be future-proof if you wanted to go for 5.1/7.1 speakers later.
As for the Creative soundcards, no questions about their quality.
shadow2get is offline
Old 02-12-2007, 03:09 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
1) Try your speaker on other desktop.
2) Try any other speaker on your system.
Now find yourself..where is the problem.
ravi_9793 is offline
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
onboard sound vs sound card ritwickgupta Hardware Q&A 4 23-06-2006 02:22 PM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
