Old 01-12-2007, 03:09 PM   #1 (permalink)
New
New's Avatar
Default Does AsusGoldfish2 support PCI-E?
Hello friends.. U can view my system configuraion in my signature.. I am going to buy one graphics card for this configuration.. I had asked this question here quite time back.. I am planning to buy XFX 8400 GS today from sp road bangalore.. PC Wizard shows that my M/B supports PCI-E..But in compaq site they have given that it suppors only PCI(no AGP slot also)..Can anyone tell me does this support PCI-E?If not please suggest me a good PCI card for around 2.5k.Also suggest a AGP card for the same price(for my friend).I have attached pc wizard screen shot .. Please check it out.
Thank you..
New is offline
Old 01-12-2007, 03:36 PM   #2 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Default Re: Does AsusGoldfish2 support PCI-E?
As if u see this link, u will see that this mobo doesn't have AGP slot and also not PCI-E!
It has 3 PCI slots but i don't think PCI cards are available!
I suggest u buy a PCI-E based board as it will be available easily for u because u have a LGA 775 processor!
keith_j_snyder2 is offline
Old 01-12-2007, 03:41 PM   #3 (permalink)
New
New's Avatar
Thanks for the reply..Is There any M/B which support both P4 processor and Quad core(i think it's no there).. So that i can change only M/B now and can bring quad core after some time..
New is offline
Old 01-12-2007, 04:30 PM   #4 (permalink)
Rising ApocalypsE
Good Choice!
Yes there are motherboards which supports both P4 and Quad Core and since u have 775 Socket motherboard then there are unlimited choices!
But u have to change ur RAM too since all quad cores will be using DDR2 or DDR3 RAM but u have DDR1 RAM so if u buy the motherboard compatible with Quad core u will have to upgrade lots of things.
Best option is go for a DDR1 motherboard available from various brands and upgrade everything when u will be upgrading to Quad cores!
U can go for:
Intel D101GGCL @ 3750/-
Intel 915GAVL @ 4200/-
ASUS P5RD1-VM @ 3150/-
Old 01-12-2007, 05:17 PM   #5 (permalink)
New
New's Avatar
Thanks...
Suppose if i go to quad core M/B what all component i have to change?
But I am interested in buying a M/B which supports DDR2 or 3 as DDR2 RAM is very cheap compare to DDR.. Can you suggest a M/B which has onboard Graphics?
New is offline
Old 01-12-2007, 05:52 PM   #6 (permalink)
Rising ApocalypsE
U will have to change the processor, motherboard, RAM or may be power supply(if it is less than 450 W)
DDR3 RAM costs a fortune now days so if u really want a Quad core for future, u have ample options depending on your budget!
Post your budget and i will give u the best config available or refer to chooto cheeta thread
Old 01-12-2007, 05:55 PM   #7 (permalink)
New
New's Avatar
My budjet is 7K for Motherboard (onboard Graphics)and RAM(2GB)
New is offline
Old 01-12-2007, 09:19 PM   #8 (permalink)
Rising ApocalypsE
this budget is for Motherboard and ram...both?
Old 01-12-2007, 11:12 PM   #9 (permalink)
New
New's Avatar
Apologies for the delay..
Yaa it's for both RAM and M/B.. Won't i get a single PCI card?Actually I was planning to buy a Graphics card and 2GB of Ram for my system in that 7k
New is offline
Old 02-12-2007, 03:22 AM   #10 (permalink)
Rising ApocalypsE
Well there is a large list for these motherboards but u need atleast 2 GB RAM which should be for 1X2 Gb @2000 /-
So that leaves u for 5000/- for motherboard:
BIOSTAR GF7050V-M7 @ 3350/-
http://www.biostar.com.tw/app/en-us/...t.php?S_ID=307
And INTEL DG33FB http://www.intel.com/cd/channel/rese...ture/index.htm @ 5000/-
Even the Q6600 is a cheapest Quadcore which supports 1066 MHz FSB but in coming time there will be 1600 MHz FSB Penryn processors which will be really awesome!
Then u will have to compromise on to Q6600 only or any other Quad core available at that time!
But by far this is the best suitable option for u!
Old 02-12-2007, 10:28 PM   #11 (permalink)
New
New's Avatar
Thank you very much friend...Will buy the same next sunday...
New is offline
N70 and AAC support.........help.... expertno.1 Mobiles and Tablets 3 09-11-2007 05:14 PM
support for HW T&L makarand Gamerz 1 03-04-2006 08:43 PM
HP Support kjsingh511 QnA (read only) 3 08-10-2005 12:46 AM
Dap does not support...... pirates1323 QnA (read only) 5 05-04-2005 09:33 PM
