Old 01-12-2007, 01:24 PM   #1 (permalink)
PowerDaemon
Musicmaker23's Avatar
Default HP dv9222tx Laptop needs your help to UPGRADE
i've owned a Pavilion dv9222tx (17") for bout 7 months now:
Intel Core 2 Duo T5200 1.6 Ghz
x86 Based PC
1 Gb RAM (2 x 512 mb)
160 Gb Toshiba ATA
NVIDIA Go Geforce 7600 256 Mb
Integrated card reader, bluetooth, wlan etc etc
Windows Vista Home Premium & Office 07
The system isn't upto my requirements as i realize it now - I absolutely love Vista (inspite of what many others say), but, it eats up too much RAM.
I've decided to upgrade the Processor & RAM & have the following problems:
1. Will i need to reinstall any of my current softwares?
2. My Laptop Config says "Max 2 gb Compatibility" - What does this signify? Why can't i go & upgrade to 4 Gb?
3. Do i need to worry about any specific processor related problems? How high can i go with intel on my current laptop?
4. will all of this affect my motherboard?
Musicmaker23 is offline
Old 01-12-2007, 02:49 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: HP dv9222tx Laptop needs your help to UPGRADE
You can only upgrade the RAM. 1GB x 2. Single 2GB soDIMM would be too costly anyways.
There's no retail market for notebook processors in India. So, the only way to upgrade your laptop CPU with a faster one is by getting it from US. Upgrade to T7200 should be good enough. The newer processors are Socket-P based, you need Socket-M ones. The highest you can go is T7600.
No software reinstall is required. No other processor or motherboard related problems.
Sourabh is offline
Old 02-12-2007, 01:25 PM   #3 (permalink)
PowerDaemon
I bought the laptop primarily cause it had everything i could ask for as far as wireless & software features go (& even compromised on the processor a bit cause better ones were unavailable on a 17 incher at the time) .. I looked up intel.com about their newer processor & as u said P sockets are required for anything beyong the T7600.. Is there anyway to go beyond that i.e change the socket or sumthing (plz don't laugh if you found what i asked you very stupid.. i'm a lil' new to the technical aspects of mobos)?
& plz mention about the MAX RAM.. 2gb.. can't i go beyond that if i wanna spend the cash?
Old 03-12-2007, 06:49 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
It's not possible to change sockets.
Although HP says max 2GB RAM in datasheet, 945PM chipset can accept up to 4GB.
Sourabh is offline
help on laptop upgrade from T2300 to T2600 tech_lover Hardware Q&A 5 18-07-2007 01:47 AM
Buy/Upgrade-PC/Laptop! Anindya Hardware Q&A 6 14-07-2007 12:29 PM
What can Be upgrade in a Laptop? prakhar18 Laptops and Netbooks 1 24-03-2007 08:42 PM
internal hard drive upgrade for laptop sachin_libra Hardware Q&A 1 30-01-2007 01:30 PM
Laptop memory upgrade Nemesis Laptops and Netbooks 2 02-08-2004 11:53 PM
