Old 01-12-2007, 12:19 PM   #1 (permalink)
Default Do u recommend this laptop?
guys i would like to have your opinion if i should buy this toshiba laptop
Toshiba P200-12D
General
MPN: PSPB6E-02J028EN
Platform Technology: Intel Centrino Duo
System Type: Notebook
Built-in Devices: Stereo speakers, wireless LAN aerial
Width: 39.9 cm
Depth: 28.8 cm
Height: 4.6 cm
Weight: 3.3 kg
Processor
Processor: Intel Core 2 Duo T7100 / 1.8 GHz
Multi-Core Technology: Dual-Core
64-bit Computing: Yes
Data Bus Speed: 800 MHz
Chipset Type: Mobile Intel PM965 Express
Cache memory
Type: L2 Cache
Installed Size: 2 MB
Ram
Installed Size: 2 GB / 4 GB (max)
Technology: DDR II SDRAM - 667 MHz
Configuration Features: 2 x 1 GB
Storage controller
Type: Serial ATA / IDE
Serial ATA Interface: Serial ATA-150
Storage
Hard Drive: 200 GB - Serial ATA-150 - 5400 rpm
Optical storage
Type: DVD±RW (±R DL) / DVD-RAM / HD DVD-ROM
Read Speed: 24x (CD) / 8x (DVD) / 1x (HD DVD)
Write Speed: 24x (CD) / 8x (DVD±R) / 2x (DVD-R DL) / 2.4x (DVD+R DL)
CD / DVD Rewrite Speed: 10x (CD) / 4x (DVD±RW) / 5x (DVD-RAM)
Card reader
Type: 6 in 1 card reader
Supported Flash Memory Cards: SD Memory Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, SDIO
Display
Display Type: 17.1" TFT active matrix
Max Resolution: 1440 x 900 ( WXGA+ )
Widescreen Display: Yes
Colour support: 24-bit (16.7 million colours)
Features: TruBrite
Video
Graphics Processor / Vendor: ATI Mobility Radeon HD 2400
Video Memory: 128 MB
Total Available Graphics Memory: 895 MB
Audio
Audio Output: Sound card
Compliant Standards: High Definition Audio
Features: Harman/kardon stereo speakers
Notebook camera
Camera Type: Integrated
Sensor Resolution: 1.3 Megapixel
Input device(s)
Type: Keyboard, touchpad, multimedia control panel
i am getting this for around 46K
Also tell me about the support, durability of toshiba laptops
thanks
raja2281 is offline
Old 01-12-2007, 12:29 PM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: Do u recommend this laptop?
Well I have no idea about the toshiba lappys but I think they are giving too much for too less.
cynosure is offline
Old 01-12-2007, 12:29 PM   #3 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
i think it is great configuration i recommend this
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 01-12-2007, 04:08 PM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Yeah this is really cool config. and one of my friend had TOSHIBA laptop and he was quite satisfied with its performance. He even said it is better than Compaq!
Besides it is also Dx 10 graphics for best multimedia options like watching movies and casual gaming!
keith_j_snyder2 is offline
Old 01-12-2007, 04:25 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
ultimate man!
I recomend this not only for you, but for others wanting to buy a <50K lappy as well. the procesor could have been better at the screen size's cost though.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 01-12-2007, 04:51 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Looks gr8 @ 46K
ravi_9793 is offline
New PC..please recommend abyssman QnA (read only) 9 30-05-2006 08:27 PM
New PC ..please recommend abyssman Hardware Q&A 7 29-05-2006 04:39 AM
which HDD will u recommend??? ~Phenom~ Hardware Q&A 24 25-05-2006 03:55 AM
What do you recommend? cooldip10 Gamerz 8 11-05-2006 10:58 PM
Recommend me overdose_14 QnA (read only) 3 11-03-2006 03:31 PM
