Old 30-11-2007, 10:07 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Wink Connecting A Cassette Tape Music Deck To PC ?
Hi Guys ,
I am having an Antique Sanyo Cassette Tape Music Deck which is of no use now , but its speakers are quite powerful !
I wud lyk to ask u ppl whether is it possible to connect that deck with my pc and avail the enjoyment of the speakers ?
here are a few pics of the speaker leads and instrument panel at the back of the deck !
The speaker lead connecting to the deck is different than what we use in PC's soundcard , therefore is there any connecting lead also available ? Plz explain what to do in detail .
Speaker Lead - Side View
Speaker Lead - Top View
Console At The Back Of The Deck
Thnx
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 30-11-2007, 10:12 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Connecting A Cassette Tape Music Deck To PC ?
I guess you want to connect your speakers to Pc,right?
If so Cut the lead in pic1 & replace it with stereo pin(The one used in headphones i.e 3.5mm).
Then you should be able to connect it.
Hope this helps.
Cool G5 is offline
Old 30-11-2007, 10:32 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
Wait.. Wait Wait!! Don't do any cutting-shutting.. You need a simple cable. This is how the cable looks like:
This is called Stereo to RCA cable. You'll get it in electronics shop. May cost less than 50 bucks (again, depends on quality). You will get that cable in different lengths.
Just plug the single connector to "Speaker/Audio Out" on your computer (Green connector to which you connect your 2.1 speakers or Headphones). Plug the other two connectors (grouped) to the AUX IN (or whatever "IN" is there) of your amplifier. Now just power on your amplifier and set the mode to AUX IN (or to whatever "IN" you've plugged in), adjust the volume and voila! Its done
infra_red_dude is offline
Old 30-11-2007, 11:04 PM   #4 (permalink)
be careful, i once rendered my sound card dead by using external speakers(not meant for PC).
I remember i was playing Delta Force: Black Hawk Down and everything was guns blazing boom and suddenly i heard another boom and that was my external speaker,capacitor popped out .
After that i removed the jack only to realise that the soundcard was no more working.
Faun is online now
Old 01-12-2007, 09:51 AM   #5 (permalink)
Thnx Infra , will surely try it out !
@ T159 , i'll be careful !
Old 01-12-2007, 10:12 AM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
i smoked mine when i connected it to the tv audio in
http://beingmanan.com
iMav is offline
Old 01-12-2007, 02:25 PM   #7 (permalink)
Wire muncher!
^^^ I've connected my Laptop to my Music System so many times and even to TV AV IN many times. Its perfectly fine here
Old 01-12-2007, 08:59 PM   #8 (permalink)
infra , working here fine too ... thnx a ton ! o man , i just can't tell , the speakers are rocking ! the window vibrate at just level 2 of volume ! there are 20 levels , so u can image very well
Old 01-12-2007, 09:16 PM   #9 (permalink)
lol
Faun is online now
Old 02-12-2007, 12:13 AM   #10 (permalink)
amanjagga's Avatar
hey workinf fine with my music system but for TV................................. .I bought the third motherboard
www.hhostingg.com
amanjagga is offline
Old 02-12-2007, 12:33 AM   #11 (permalink)
Wire muncher!
^^^ I haf no idea why its happening. Its working fine for me since 3 years!!! Anyway, threadstarter: Heed to their warning and refrain from connecting it to your TV, to be on the safer side.
Old 02-12-2007, 07:12 PM   #12 (permalink)
Especially in older TVs, there might be high voltage on the chassis and the line in's ground terminal. TVs typically dont have earthing. If u connect it directly to ur PCs line out, maybe this high voltage could cause problems.
gulgulumaal is offline
Old 02-12-2007, 07:20 PM   #13 (permalink)
Wire muncher!
Might be a possiblity. But mostly the connectors are well isolated and the casing is made of fibre. Thats the reason why most of the TV plugs don't haf the earth pin.
Old 17-12-2007, 04:28 PM   #14 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
popin this months dvd [archieve] ..... & july 2006 mag has detailed info .......
... W H O T ...
ax3 is offline
can we upload music from tape recorder to pc? ParadoX QnA (read only) 22 06-08-2009 04:31 PM
copying music from casette tape to computer skdas_30 QnA (read only) 3 21-12-2006 11:16 PM
Gonna buy a ngage qd deck. aku Buying Advice 6 30-06-2006 02:59 PM
Buying a new Nokia N-Gage Gaming Deck-QD !!! rachitboom2 QnA (read only) 7 20-05-2005 10:52 PM
Cassette to Cd ganesh_2218 QnA (read only) 8 18-11-2004 07:41 PM
