Old 30-11-2007, 04:23 PM   #1 (permalink)
Stuck
Unhappy Pen drive gone kaput !!
I have a zion 256 mb pen drive. some days ago, i took it 2 my college computers, for transfering some files. It (the pen drive) worked fine for a few days but then i found a folder named 'music' in it, which i had not made. I deleted it but it again came back. Then I formated and scanned my drive with avast antivirus but it didn't show any problems. Now, when I enter the drive by double clicking on the pen drive, an application runs for a very short while and then my av shows that there is some 'trj' in it. I've tried to format it again n again, but the problem persists. Please help me i'm in big trouble coz i need my drive badly.
Vivek.28 is offline
Old 30-11-2007, 04:24 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Pen drive gone kaput !!
^^ just use any Linux live CD and format it.
Charan is online now
Old 30-11-2007, 04:31 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
The infection isn't residing on your pen-drive. Its your PC which's infecting anything you plug in to it. So, look at the right place
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-12-2007, 04:45 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
scan your PC in safe mode/via live A/V
format Pen Drive via some live distro.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 01-12-2007, 06:42 PM   #5 (permalink)
respect mah authoritah!!
girish.g's Avatar
the problem is in your PC run a virus scan on it
im not sure about formatting because i had the same problem and my pen drive stopped working i had to repair it from nehru place
girish.g is offline
Old 01-12-2007, 07:04 PM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
There are place which service Pen Drives? What did they do? Im jus curious cause I never knew that there were replaceable parts in a pen drive.
But I would also check your system first. But other than that you can use the HP Formatting tool to download a tool which can be used to format Pen Drives also. I used this to format my USB stick to use to Boot NimbleX.
FilledVoid is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
USB drive gone kaput :X sagsall4u Hardware Q&A 15 13-09-2007 01:20 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
