I installed a system the other day and everything was fine and the customer was very happy with his new AMD Athlon x2 , 6000 system.
But during install of their 320GB HDD, XP setup was only showing the disk at around the 170GB size!!!!
and then during the actual XP install it encountered a cyclic redundecy error!!.
I then went to install XP from a different XP disk and all went well, but after remoting into their system yesterday and installing
speedfan for them, the HDD was running at 50oC idle!!!, then ten minutes later, they phoned me up to say smoke was pouring out of the pc
as you can see(bit blurry) the sata connector has shorted out on the two centre pins of the HDD circuit board!!!
Is this a common fault or/and a good case for returning drive for replacement?
All the rest of the hardware is fine because it's now working with an old IDE drive for now .
