Old 30-11-2007, 11:52 AM   #1 (permalink)
Exclamation TFT display problem
i have a sony sdm-e76a tft monitor. for the past few months a green tint is present in the display which is clearly visible in dark places.
what may be the problem??
slyfox is offline
Old 30-11-2007, 01:04 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: TFT display problem
try wither another ystem if possible and if there too problem, then its time for u to contact Sony support if u have warrenty left !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 01-12-2007, 01:49 AM   #3 (permalink)
what if it works fine another system?
slyfox is offline
Old 01-12-2007, 09:16 AM   #4 (permalink)
have your pc's problem sorted out! isn't it simple logic?
V.Prem Kumar
janitha is offline
Display problem babuli_05 Software Q&A 8 14-12-2007 01:57 PM
Display Problem Ron QnA (read only) 2 11-08-2007 08:24 AM
Display problem??? Curious Guest QnA (read only) 5 14-02-2007 10:53 PM
Display Problem salztech Hardware Q&A 4 14-07-2006 11:44 PM
Display Problem sudhirkumar001 QnA (read only) 9 05-10-2005 12:02 AM
