Old 29-11-2007, 09:35 PM   #1 (permalink)
Default JET FLASH Usb drive problem
getting always a write protection error whenever i copy files to the flash drive.
googled a lot but no solution.
It's a transcend 2A series 512 MB pen drive.
mrbgupta is offline
Old 29-11-2007, 11:02 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: JET FLASH Usb drive problem
This was one error which had driven me mad a while ago!!I faced this issue on my mobile's memory card.
Go to My Computer.Right click on your flash drive.Navigate to Properties>Hardware.Select your flash drive from the list.Click on Properties>Policies>Optimize for Quick Removal..Save the settings.It worked for me.
Note: this will affect your transfers rate a bit.
Life is as complicated as you say it is.
shady_inc is offline
Old 30-11-2007, 10:55 AM   #3 (permalink)
no way same error !!!!!!!!
mrbgupta is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Toshiba 8 GB USB 2.0 flash drive giving problem sanju Hardware Q&A 3 25-11-2007 11:48 AM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Flash Drive problem? vinith98 Hardware Q&A 3 31-01-2007 06:20 PM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
