Old 29-11-2007, 02:23 PM   #1 (permalink)
Dishant's Avatar
Default Recover BIOS password!!
hello,
the problem i'm facing is someone has password protected my BIOS,.now i can't log into it to use my pc.....i want to recover the password ..is there any way to overcome it...waiting for reply!!!
Dishant is offline
Old 29-11-2007, 02:34 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Recover BIOS password!!
I want to recover the password
Sorry to say you cant recover BIOS Password... There are no option for such...
Yes there is, which is resetting the BIOS to the default !!! you did not mention the exact motherboard model so cant tell u where exactly to look, so refer to ur mobo manual for the location of the jumper...
which may look like this,
So unplug the cap from the defatult 1-2 settings and plug it in as 2-3 settings...
restart the system... it will clear every thing... shut down and then agian set the jumper to old 1-2 setting... now start the system again to use it
another option is to remove the BIOS / CMOS battery...
remove the battery for 5 mins... plug it again to start using the computer
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-11-2007, 03:09 PM   #3 (permalink)
smile's Avatar
u can take out the CMOS battery and again after 1 min u can insert it....and switch on the system
SR
smile is offline
Old 29-11-2007, 03:28 PM   #4 (permalink)
Deadman Walking
Batistabomb's Avatar
i came to hear some technique of pressing F and G keys on keyboard while system is about to ON will reset password,is this true
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 30-11-2007, 06:54 AM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
Can you boot to DOS, If yes let me know and I will tell you a way.....
sam9s is offline
Old 30-11-2007, 09:46 AM   #6 (permalink)
darklord's Avatar
Isnt the BIOS password required before booting ?
darklord is offline
Old 30-11-2007, 09:56 AM   #7 (permalink)
dOm1naTOr's Avatar
nice work choto
the images tells everythin.
@smile
sometimes the bios will not be reset if only 1 min the battery is removed coz itll take some time for the oscillatory current to die out without the feedback from battery. It varies from each system. For some it may take upto 30min!
The best way is dat jumper one.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 30-11-2007, 10:10 AM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
Nope if the BIOS pass is set to system, in that case you need it only while entering the BIOS. Though he mentioned he cant log on to PC but I still was in doubt n thats is why I asked to confirm........
sam9s is offline
Old 30-11-2007, 10:26 AM   #9 (permalink)
a_k_s_h_a_y's Avatar
removing the CMOS battery and reinserting it after 10 minutes and starting PC won't work
instead Remove CMOS battery and then start computer with out that CMOS battery and setup up things and then again put it back in its place and start computer ! and set up CMOS defaults
atleast for me its this way and even on all my friends computers
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 30-11-2007, 11:18 AM   #10 (permalink)
dOm1naTOr's Avatar
@a_k_s_h_a_y
try to keep the system for more than 30min without the battery nd dun turn on. It surelly worx
G3: XPS M1530 |
FZ 16.
Recover windows XP password. cynosure Software Q&A 3 24-10-2006 02:58 PM
How to recover Hotmail password? redhat Internet & WWW 1 13-10-2006 01:45 PM
BIOS updates - How to recover sagargv Tutorials 16 22-03-2006 09:35 AM
Recover corrupt BIOS sagargv Hardware Q&A 1 28-01-2006 09:10 AM
Recover XP Password (Not reset) enjoy Software Q&A 3 14-09-2005 09:28 PM
