Old 28-11-2007, 05:40 PM   #1 (permalink)
smile's Avatar
Default Ram Modules
I need to upgrade my ram as am having 128 mb ddr (266 Mhz) ram..i want to add more 256 mb...but the problem is my friend is having 256 mb (333 Mhz ).My question is if i install different speed of ram will it work or i will have a problem??
SR
smile is offline
Old 28-11-2007, 07:42 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Ram Modules
Yes.The RAM will run at the speed your motherboard supports.So a 333 Mhz RAM will work at 266 Mhz in your case.
Life is as complicated as you say it is.
shady_inc is offline
Old 28-11-2007, 08:34 PM   #3 (permalink)
smile's Avatar
so the different speed of ram will work ??????????
SR
smile is offline
Old 28-11-2007, 08:37 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
yeah they are expected to work fine... and without any issue... you may use the new 333 MHz RAM along with the 266 MHz module.. as already said the new 333 MHz RAM will run as the lowest frequency running which is 266 MHz...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-11-2007, 01:09 AM   #5 (permalink)
smile's Avatar
thanks a lot
SR
smile is offline
RAM Different Modules stellar Software Q&A 8 22-07-2007 10:24 PM
Samsung RAM Modules? ambandla Hardware Q&A 4 24-04-2007 10:58 PM
How many RAM modules should I go for? kunalmg Hardware Q&A 11 02-07-2006 01:47 PM
Installing Ram Modules n.regmi Hardware Q&A 8 22-06-2006 08:23 AM
RAM Modules --- Help Needed rockthegod Hardware Q&A 20 03-12-2005 08:07 PM
