Old 27-11-2007, 02:24 PM   #1 (permalink)
Amir.php's Avatar
Question r-connect problem
i have recently upgrade my system to murcury(intel 82945 chipset)moherboard,dual core processor,1gb ram etc.
after installing the usb cable and my LG RD 2130 modem when i tried to connect my system is Hang up.i try again but system hang again and again.
while on my old configuratin i have been successfully use internet using this setting as well as this cable and modem.
My os is xp professional.
the same problem also srises on vista.
please give me some suggetions.
Amir.php is offline
Old 27-11-2007, 02:29 PM   #2 (permalink)
Default Re: r-connect problem
Remove drivers and reinstall.Try on another computer.
ThinkFree is offline
Old 27-11-2007, 02:36 PM   #3 (permalink)
Deadman Walking
Batistabomb's Avatar
can you tell clearly what is the need for usb cable here,also in modem properties verify whethet it was diagnostic or not,if not reply soon here
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 27-11-2007, 02:38 PM   #4 (permalink)
Amir.php's Avatar
No
Amir.php is offline
Old 27-11-2007, 02:43 PM   #5 (permalink)
Deadman Walking
it was not diagnostic did you saw it,on clicking diagnostic what is the msg you are getting
Learn to live... &
Live to learn...
Old 27-11-2007, 02:53 PM   #6 (permalink)
Amir.php's Avatar
at this time i am not on my system .
please tell me solution on both cases
Amir.php is offline
Old 27-11-2007, 04:23 PM   #7 (permalink)
Deadman Walking
ok amir right clock modem properties->diagnostic and if any error msg like
"your modem is not turned on,please check it for any loose connection"
then uninstall the modem and remove modem from slot and connect a bit tight try this in all your 3 or 4 slots,if still the error exists verify if you are using the correct drivers if still then this may be some conflict with your mobo,no solution for this except buy a new modem
Learn to live... &
Live to learn...
Vodafone Mobile Connect Problem ::cyborg:: Buying Advice 3 09-04-2008 12:05 PM
A problem when I connect to Internet ramprasad Internet & WWW 4 01-12-2004 05:50 PM
R-CONNECT PROBLEM venu2004 QnA (read only) 5 05-10-2004 06:32 PM
