Old 26-11-2007, 02:41 PM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Mobo for C2D E6750
(need it by today itself)
i m buying a cpu under 20K...
i n goin for C2D E6700 or E6750 (its aroung 8000/-)
plez suggest a good mobo below 7000/- (overclocking not necessary, wud prefer one with E-sata port)... i m planin 2 add a 8600 GS, but a little later.
DO both P965 & P935 support E6750???
is it better 2 go 4 a mobo with internal graphics??? as i m not gettin a graphics card 4 sometime.
also plez suggest ASUS or MSI as other brands r hard 2 find here (i m in girgaon, haryana).
my current options are : MSI P965 neo , MSI P963 neo, MSI G33
ankushkool is offline
Old 26-11-2007, 02:50 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Mobo for C2D E6750
Abit IP35e.
Pathik is offline
Old 26-11-2007, 03:08 PM   #3 (permalink)
ankushkool's Avatar
Originally Posted by pathiks
Abit IP35e.
plez suggest ASUS n MSI... dont get abit, biostar even gigabite here
Old 26-11-2007, 03:50 PM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Visit the asus/msi main homepage and select yourself a motherboard from their products list.After selecting a motherboard google for its reviews and problems faced by users.
Harvik780 is offline
Old 26-11-2007, 06:31 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Asus P5k
Pathik is offline
Old 26-11-2007, 06:47 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
Did you miss this sticky ??
Basic Guide Purchase a New System
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-11-2007, 10:03 PM   #7 (permalink)
moshel's Avatar
better if u go for the newer G33 based board....it has a bit higher version of onboard graphics than the 965G...
as for the make...Asus..just check it up on their website.
moshel is offline
Old 26-11-2007, 10:12 PM   #8 (permalink)
Asus P5K-VM....onboard gfx,G33 chipset,~8k.
Let there be music.....
sashijoseph is offline
Urgent Help regarding motherboard for E6750 sainit Hardware Q&A 15 18-09-2007 03:42 PM
Amd processor + Mobo + Ram urgent ! eureca_eureca Hardware Q&A 8 30-10-2006 08:20 PM
urgent help req. mobo=psu choudang CPU / Motherboards 2 30-12-2005 08:46 PM
