Old 26-11-2007, 08:29 AM   #1 (permalink)
Edburg's Avatar
Default My PC is freezing frequently...help
I had replaced my motherborad(zebronics 845GV),RAM recently bcos of some failures....
but ever since i did that my system is freezing freqently......restarting is the only option then...
when i run torrents or normal browsing it stays alive for a few hours.....when i switch on the songs or even flash intensive websites or anything which even requires a little work,the system hangs....
help me in this please...i think harware problem is the cause as i have instlled several windows too....
Things which i have tried :
1) there is no temp checiking in my crap mobo
2)Ran memeory test and orthos which seems fine until system freezes as usual
Edburg is offline
Old 26-11-2007, 09:00 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: My PC is freezing frequently...help
You need to re-install your windows.
Because
your current windows reads old motherboard..but now you have different motherboard.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 26-11-2007, 10:48 AM   #3 (permalink)
Edburg's Avatar
Because
i have already done that...infact that was the first thing i did after changign mobo....i tried formatting whole harddisk and then installed windows too...
Edburg is offline
Old 26-11-2007, 10:56 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Than , as you said..problem started after upgrading motherboard and RAM.......so, 90% change is hardware issue.Try your system with old motherboard and RAM.
TechTin.com
Old 26-11-2007, 02:33 PM   #5 (permalink)
Edburg's Avatar
^^but both the old RAM and mobo are dead......
Edburg is offline
Old 26-11-2007, 02:52 PM   #6 (permalink)
Google Bot
Pathik's Avatar
Yup .. its better to do a fresh install after doing major changes in the hardware..
Pathik is offline
Old 26-11-2007, 04:13 PM   #7 (permalink)
Remove all extraneous stuff like pci cards etc.Update all drivers,esp sound and graphics.Borrow a friend's smps.Immediately after freezing,restart,get into the bios and note the cpu temp.When reinstalling the cpu did you apply thermal paste?
Hope one of the above clicks for you.
Let there be music.....
sashijoseph is offline
Old 26-11-2007, 04:22 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
There are many reason of PC freezing...but your case looks like hardware compatibility.So, better take to vendor..and get it fine.
TechTin.com
Old 26-11-2007, 04:24 PM   #9 (permalink)
Dreamweaver
Gigacore's Avatar
and even the CPU high temp too
Gigacore is offline
Old 26-11-2007, 08:20 PM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
I think it's a possible Ram issue.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
Old 26-11-2007, 09:08 PM   #11 (permalink)
Edburg's Avatar
Guys i tested orthos for my CPU for about 2 hours and it ran stable and then i stopped it....
then i ran memory test which was in the live linux CD....it also ran fine...
so i think the heat/temp isssue in pro and prob in RAM is not there....
@ravi the prob with goin to vendor is that the system freezes only some time......when i go to vendor the sys may not freeze at all.....
and sound drivers are not at all installed......updated video driver....crappy zebronics dont have any support at all for thier mobo...how can i update the bios ?
so prob must be with bios/mobo,hard disk or smps....how can i test these like the ram and cpu without having to replace them with another one ??
Edburg is offline
Old 27-11-2007, 12:41 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
did u scandisk [4 bad sectors] & defrag ur C drive ........
check 4 bad sectors ......
... W H O T ...
ax3 is offline
Old 27-11-2007, 03:40 PM   #13 (permalink)
Edburg's Avatar
yeah i checked them....no bad ones.....defragmentting now...
@ax3...sorry for the other one....that one had different probs than this.....after changing those i had other probs...so started a new thread for these new problems..
Edburg is offline
Old 28-11-2007, 12:46 PM   #14 (permalink)
ax3
ax3's Avatar
no problem frd ..... a just wanted 2 point it out .... sorry from my side ....
& problem is problem ..... i know, its time 2 panic & solve it as soon as possible .....
mine freezes 2 ..... applied both & it was solved ......
hope its same on ur side 2 ........
... W H O T ...
ax3 is offline
XP freezing NIGHTMARE Software Q&A 4 03-10-2007 12:44 AM
pc freezing with a cracking sound r_raman Hardware Q&A 11 29-01-2007 03:27 AM
Freezing Opera...... vrnoormd Software Q&A 10 03-01-2006 05:09 PM
HELP ME!!! MY PC IS FREEZING sreevirus Software Q&A 5 10-10-2004 12:47 AM
Why only games are freezing? bhalchandra Software Q&A 8 06-09-2004 07:11 PM
