I have a 8GB Toshiba USB 2.0 flash drive now a days it is not working properly. Whan I copy data in it it copied successfully but againg when i open it It say folder is empty ??? what is the problem with my flash drive I can't understand? I have formatted it but the problem is the same.
Anybody has the solution????
plz?
Re: Toshiba 8 GB USB 2.0 flash drive giving problem
Originally Posted by Choto Cheeta
Did you try in different computers ?? all produce the same result ?? if yes then may be time to take it to the service center !!!!
thanx for the response.
yes checked on other computer, and got the same result. When copied to usb pan drive all data was not deleted but some folder it show that empty.
