Old 23-11-2007, 06:21 AM   #1 (permalink)
An Esoteric Geek
sridatta's Avatar
Default Temperature Levels for my 8500GT
When i open Nvidia access manager to view my graphics card temperature, i always find it around 70 when idle.. One of my friends told that it is not a good sign..
I have XFX nvidia 8500GT graphics card.. and it is shipped with a small heat sink.. i didnot install any other cooling system for that..
Please suggest me the solution..
sridatta is offline
Old 23-11-2007, 09:13 AM   #2 (permalink)
Default Re: Temperature Levels for my 8500GT
70 Degrees Idle is kinda high. Case is ventilated enough?
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 23-11-2007, 10:48 PM   #3 (permalink)
An Esoteric Geek
sridatta's Avatar
one side of the case is always kept open..
i have installed a LAN card in the PCI slot which stays almost 1 inch away from the graphics card.. is that the reason why my idle temperatures are high??
sridatta is offline
Old 23-11-2007, 11:04 PM   #4 (permalink)
Alpha Geek Banned
bikdel's Avatar
no... is your card XFX ? oh yeah.. thats the reason.. don't know why but XFX cards generally heat up more... though i havent witnessed as 8500 GT heating up..
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 24-11-2007, 12:51 AM   #5 (permalink)
Smitten by Computers..
raptorz's Avatar
I too own an XFX 8500GT. Is idles at 62, touches 68-70 only when i play games for a long time.
There were somethings Man was never supposed to know, for everything else there is Google..
raptorz is offline
Old 24-11-2007, 08:53 AM   #6 (permalink)
Mine Galaxy 8600 GT idles at 45-46. [Closed Case]
Tech_Wiz is offline
Old 24-11-2007, 02:14 PM   #7 (permalink)
An Esoteric Geek
sridatta's Avatar
everyone suggested me to purchase xfx
so.. is there any cheap solution for decreasing temperature levels?
sridatta is offline
Old 24-11-2007, 03:58 PM   #8 (permalink)
Buy a Rs. 75 Chassis Fan. That can help you lower down the temp a bit. Fix it in a manner that it will blow exactly on Gfx card.
Tech_Wiz is offline
7600gs or 8500GT ????? frederick_benny_digit Hardware Q&A 3 16-07-2007 10:33 AM
NFS MW levels lost...How to regain them??? reddick Gamerz 4 08-05-2007 01:03 PM
Can u Hack ur way through all levels ???? hemant_mathur Technology News 9 30-09-2006 01:46 PM
Half life2 : FPS dropping too much in some levels. darkstorm Gamerz 8 22-08-2005 09:57 AM
how to install additional bounce levels on ngage?? anispace QnA (read only) 8 05-01-2005 03:50 PM
