Old 22-11-2007, 02:00 PM   #1 (permalink)
Unhappy Strange shutdown Problem!!!
Guys I'm having a strange problem lately whose cause I'm not able to trace. I have the follwing config-intel dg965ry mobo,core e6400,trans 1 gb ddr2 533, 250 gb sata2, vista ultimate.
The problem is that the pc boots normally but after working for a few min the system shuts down without any warning, but the power led still remains on for some time. Also, the pc does not start for a few min even after the power on button is pressed, so i have to wait for 10 min before it starts again. I thought it was a overheating issue so i checked the connections, updated the bios and other drivers , still the problem continued.I tried to get the mobo replaced through intel but it returned after a few days with "no defect found " and the problem continued.
I have checked all the temperatures with intel idu but all are normal.So,now I'm really at my wits end so pleaseeeeeee help me.
digster is offline
Old 22-11-2007, 02:46 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Strange shutdown Problem!!!
was it working fine in past.Are you sure you don't have any compatibility issue.
If yes, than try these:
1) Clean processor fan
2) check SMPS, cabinet and processor fan.They must run smoothly without any noise.
3) Try changing SMPS.
4) Remove all PCI and external devices like....Graphics card (if you have any)...printer, Tv tuner card digital camera
The most possible cause is overheating and SMPS problem.
ravi_9793 is offline
Old 22-11-2007, 03:04 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Its the SMPS definitely.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-11-2007, 04:08 PM   #4 (permalink)
club_pranay's Avatar
If the led remains on for a while, have a slight feeling that apart from smps and temperatures, the processor might be at fault. the cpu is initiating the power trip.
Please tell the results.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 22-11-2007, 06:32 PM   #5 (permalink)
Well, I tried all the cleaning and rejoining stuff but it did not work. It either has to be the smps or the cpu but i still have the feeling its mobo problem bcoz of the typical symptoms. Also, the smps maybe ruled out coz i tried one of my friends smps too.
Is there any utility by which I can check that the cpu or mobo is faulty?
One more thing, even if the smps is faulty(Zebronics) how should i relate the above problem to get it replaced through the service centre?
Also, I did like to mention that when the pc shutsdown automatically, it tries to restart again but fails after restarting 2-3 times and when it shuts down for the last time it does not start again till a few minutes evn when the power button is pressed.
digster is offline
Old 22-11-2007, 07:38 PM   #6 (permalink)
Dishant's Avatar
wat's ur smps wattage?
Dishant is offline
Old 22-11-2007, 08:03 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
is this ur new system.Was it running fine in past??
Are you sure there is no compatibility issue??
Old 23-11-2007, 06:06 PM   #8 (permalink)
Well the smps is 400 watts,zebronics make. Also, its been only 3 months that I upgraded the system.
psst: it was running well in the past before the problems began.
digster is offline
Old 23-11-2007, 06:23 PM   #9 (permalink)
coolsunny's Avatar
type EventVwr.msc in Run.than ok .. check all msgs.It might help u identifying the problem.
u can do other thing.take out ur Cmos battery & RAM both.& reinstall them.It might help u.reply if it solved.
coolsunny is offline
Old 26-11-2007, 12:55 PM   #10 (permalink)
Well, right now I hve sent my motherboard for replacement for the second time , lets see what happens.
digster is offline
Old 26-11-2007, 08:26 PM   #11 (permalink)
Same problem was also happened with me.
Check your smps.My problem was occuring because the fan of my smps was damaged.
jayanta_sarkar is offline
Old 27-11-2007, 05:53 PM   #12 (permalink)
Thx. Will try that when the motherboard comes.
digster is offline
Old 28-11-2007, 04:49 PM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
@ digster
If possible try to buy a atleast 400-450 true power smps.
Like zebronics platinum series or cooler master, VIP, corsair etc.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-11-2007, 06:31 PM   #14 (permalink)
Btw can ne1 suggest me a good (and cheap) thermal paste available in lamington? (Plz just dont tell about Silver Arctic, cant afford it right now).
digster is offline
Old 01-12-2007, 04:56 PM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ But Arctic Silver is the best one . Arctic silver retails around Rs. 350-450 Bucks.
No cheap paste ie those retails at Rs.20-30 can even come close to arctic silver.
Also cooler master is another good one. But I don't know their prices.
topgear is offline
Old 01-12-2007, 05:21 PM   #16 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Dude i think its your cabinet, is it small one?
If no then open it from all sides and see if the temp falls & possibly use an external fan like table fan and see for temp!
keith_j_snyder2 is offline
Old 13-12-2007, 12:40 AM   #17 (permalink)
Smile Re: Strange shutdown Problem!!!
Well, finally got a new board replaced instead of the old one and voila its working!!
digster is offline
Old 13-12-2007, 01:05 AM   #18 (permalink)
Rising ApocalypsE
Congrats!
XP Shutdown Problem! 2kewl Software Q&A 1 28-08-2007 10:16 AM
problem in shutdown gau_pppu Software Q&A 8 17-04-2007 10:23 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
shutdown problem atul QnA (read only) 3 31-08-2004 12:41 AM
