Old 22-11-2007, 12:13 AM   #1 (permalink)
coolsunny's Avatar
Default Suggest a good 17" TFT
Hi guys,
suggest me a good 17" TFT monitor which have no problems.I want to set it to 1024*768 resolution with 85 Hz screen refresh rate..Also inform me about the price.
coolsunny is offline
Old 22-11-2007, 01:07 PM   #2 (permalink)
Question Re: Suggest a good 17" TFT
Let me know about the other things needed for you to buy like:
* Purpose (Animation/Apps/Games/General)
* Normal (4:3) / Widescreen (16:9)
* Price Range
* Interface Type - (Analog / Digital)
* Any other specific requirement like USB ports, camera, etc
If you didn't know what the Analog/Digital Inteface means:
Analog – 15pin D-Sub (Good old interface which you have connected ur CRT for years)
Digital – DVI-D/HDMI with HDCP
This will help you to get a better monitor based on your requirements.
shadow2get is offline
Old 22-11-2007, 01:16 PM   #3 (permalink)
anand1's Avatar
Default Re: Suggest a good 17" TFT
ViewSonic with a price tag of Rs 8,000 approx
Technology On The Fly
anand1 is offline
Old 22-11-2007, 04:40 PM   #4 (permalink)
New
New's Avatar
^+1.
New is offline
Old 22-11-2007, 06:34 PM   #5 (permalink)
coolsunny's Avatar
* Price Range
its specially for Games,Viewing movies & also for general works.it should be free from ghost image or blurs.i never heard about camera integrated with TFT. if there is any model with camera ? & for interface type suggest me. please specify model no. with price.budget within 9K.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
Old 22-11-2007, 06:53 PM   #6 (permalink)
Alpha Geek Banned
bikdel's Avatar
guys im not hijacking the thread but my uncle has to use a PC in his store for cataloging and has been using a 15" CRT as a monitor. I advised him on a 14" - 15" LCD for his eyes and he agreed.
Can you advise me the cheapest LCD solution available? i dont need it to be good. Simple data entry purpose.. Dont need really branded ones like dell, aoc, viewsonic if cost can be reduced by buying a local one...
any ideas?
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 23-11-2007, 12:11 AM   #7 (permalink)
Thumbs up Re: Suggest a good 17" TFT
Ok here is the deal with the Aspect Ratios.
If it is widescreen, you get a resolution of 1440x900 but Price is More (worth it)
Else if it is Normal 4:3, you get a resolution of 1280x1024 & Price is Less.
So choose which ever you think is best. Here are the monitors you can opt for:
Specs read as Response Time, Brightness, Contrast Ratio, Native Resolution, Input Type
Normal Aspect Ratio (4:3)
* Dell UltraSharpTM 1708FP 17" Flat Panel LCD Monitor
-> 5ms, 300cd/m2, 800:1, 1280 x 1024 @ 60 Hz, Analog & DVI (HDCP)
-> Has 4 USB 2.0 high speed ports
PRICE: Rs 10,674 (inclusive of all Taxes but excluding STATEwise VAT)
LINK: http://www1.ap.dell.com/content/products/compare.aspx/17lcd?c=in&cs=inbsd1&l=en&s=bsd
* Viewsonic Monitors
>>VA703b (Black)
>>VA703m (Black & Has Inbuilt speakers)
-> 8ms, 300cd/m2, 700:1, 1280x1024, Analog
LINK: http://ap.viewsonic.com/in/products/lcd/
PRICE: Would be around 8500 - 10000
* Samsung SyncMaster 740N (Silver Color)
-> 8ms, 300 cd/m², 700:1, 1280x1024, Analog
PRICE: Rs. 9150
LINK: http://www.samsung.com/in/products/monitors/tftlcdmonitors/740n.asp?page=Specifications
* Samsung SyncMaster 732N Plus (Black Color)
-> 5ms, 300 cd/m², 700:1, 1280x1024, Analog
PRICE: Rs. 9500
LINK: http://www.samsung.com/in/products/monitors/tftlcdmonitors/732nplus.asp?page=Specifications
* Acer AL1716 Series (Silver)
-> 5ms, 300 cd/m², 800:1, 1280x1024 @ 75Hz, Analog or Dual Input
PRICE: Would be around 8000 - 9000
LINK: http://www.acer.co.in/products/product_explore_view.asp?pid=80&model=Acer%20AL171 6%20Series&cid=6
Widescreen Aspect Ratio (16:9 OR 16:10)
* Viewsonic VA1703w (Silver Color)
* Viewsonic VA1703wb (Black Color)
-> 8ms, 250cd/m2, 500:1, 1440 x 900, Analog
* Acer AL1702W (Silver)
-> 8ms, 250cd/m2, 500:1, 1440x900 @ 60Hz, Analog only
PRICE: Around 8500-9500
LINK: http://www.acer.co.in/products/product_explore_view.asp?pid=29&model=Acer%20AL170 2%20Series&cid=6
* SyncMaster 740NW (Black Color)
-> 8ms, 250cd/m2, 500:1, 1280x720, Analog
PRICE: Rs. 9000-10000
LINK: http://www.samsung.com/in/products/monitors/tftlcdmonitors/740nw.asp?page=Specifications
If I were to buy a 17" LCD monitor, I would look out for the following:
-> Lesser Response Time, Max Brightness, High Contrast Ratio, Analog & Digital Input.
-> Going for Widescreen if neccessary & any other extras like USB ports
My Recommendation would be the following:
For Normal Aspect Ratio ->>> Dell UltraSharpTM 1708FP
For Widescreen ->>> Viewsonic VA1703wb
Those are my recommendations, but Choose whichever fits in your budget.
@bikdel
If you want to go for cheap 15" LCD ones, better go to the street/shop where you buy comp. hardware from
& ask him for the cheapest available. (Actually, I don't remember the Brand names or the prices. Sorry man.)
If you want some known brands, here is the price list
L.G 15" - 7650
Samsung 15" 540N - 7900
ViewSonic 15" - 7680
ACER 15" - 7100
HP 15" - 10100
If money is really an issue, go in for 2nd hand ones. Why don't you see the Bazaar Section in the Digit Forums ?
Old 23-11-2007, 11:05 AM   #8 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
if 2nd hand .....then john is selling his 19" samsung 940BW , this monitor is best 19" TN monitor even today...
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 23-11-2007, 11:10 AM   #9 (permalink)
anand1's Avatar
@SHADOW2GET
thanks for the nice info on one board.
I refered ViewSonic because recently my friend buyed the 17" TFT with a price tag of about Rs 8,000 and it was really nice while going though it's features.
anand1 is offline
Old 23-11-2007, 11:34 AM   #10 (permalink)
Alpha Geek Banned
bikdel's Avatar
L.G 15" - 7650
ACER 15" - 7100
HP 15" - 10100
considering this, its better to go for a 19" by viewsonic.. Value for money
bikdel is offline
Old 23-11-2007, 04:28 PM   #11 (permalink)
Dreamweaver
Gigacore's Avatar
I've 15 Pin D-Sub port.. will, Viewsonic VA1703wb (Black Color) support this port ?
Gigacore is offline
Old 23-11-2007, 06:49 PM   #12 (permalink)
coolsunny's Avatar
thanks for all ur effort shadow2get...
I am thinking about Viewsonic VA1703wb (Black Color) TFT.As i think widescreen is better for movies & we get more viewing surface than the Normal one
if more featurs like intergrated web cam or USB ports available in Viewsonic ?didn't find in viewsonic site.
I will buy it next month.guys suggest me more..
Old 24-11-2007, 02:38 AM   #13 (permalink)
Wink Re: Suggest a good 17" TFT
Glad to know you picked a good one.
Check out the review for this monitor :
http://www.techtree.com/India/Reviews/Viewsonic_VA1703wb/551-83387-630-1.html
I also saw the 19" Viewsonic ones. They are also available for abt Rs. 400-600 more. Have a look @ them.
Also if you wanted some extras with the monitor, here is 1 candidate for that.
ViewSonic VX1945wm 19" Widescreen LCD Monitor with Integrated iPod Dock
http://ap.viewsonic.com/in/products/productspecs.php?id=297
Main Extras: Analog & Digital interface, iPod dock, 8-in-1 card reader, microphone, headphone jack, 3 USB port for joystick/game control, USB port for keyboard/mouse ... isn't that enough ???
Also response time is 5ms, 700:1 CR.
But it comes at a hefty Rs. 2000-3000 more.
Just letting you know. Not asking you to buy though.
Always go through some reviews done on the Monitor or user comments before you buy it.
You can check newegg.com / amazon.com for the User comments.
Google up for Reviews on the monitor.
Old 24-11-2007, 03:19 AM   #14 (permalink)
Rockstar11's Avatar
dont go for Viewsonic VA1703wb no DVI-D connector
Rockstar11 is offline
Old 25-11-2007, 01:06 AM   #15 (permalink)
coolsunny's Avatar
wht the use of DVI-D port. i think Grafix card needed for that port support.
Isn't it? none of viewsonic 17" have DVI-D connectors.
Old 25-11-2007, 02:45 AM   #16 (permalink)
Rockstar11's Avatar
hmm.. specially for games and viewing movies.???.right
1.better go for a 19" wide lcd monitor
2.lower response time : 5ms.
3.DVI
Q:
"DVI-D". What is it for?
A:
Those flat screen LCD monitors are showing up on desks everywhere. They save space, have sharper image quality, and look modern.
The old CRT (Cathode Ray Tube) monitor is an analog device. That means that your graphics card must convert the computer's digital signal into a signal that the CRT monitor can understand. Of course, there's always something lost in the process.
The LCD monitor is a digital device. If you use the DVI connection there'll be no loss of image quality or signal corruption. That is why you get a crisper image.
Here's the snag: if your graphics card doesn't have a DVI connector then you're stuck using the old VGA connection. Your LCD monitor should have a VGA connector as well, but keep in mind that you'll be getting an analog signal so it won't be as clean as purely digital. It may be worth your while to get a new graphics card with either DVI-D (digital only) or DVI-I (digital or analog with adapter) connectors so you can get the most out of your LCD monitor.
http://en.wikipedia.org/wiki/DVI
The ultimate 2ms gaming display.
ViewSonic`s 19" VX 1932WM
Response Time 2ms
DVI-D
Black color
http://ap.viewsonic.com/in/products/...ecs.php?id=317
Super Contrast Ratio widescreen.
ViewSonic`s 19" VA1926w
Response Time 5ms
DVI-D
Black color
http://ap.viewsonic.com/in/products/...ecs.php?id=328
Old 25-11-2007, 12:24 PM   #17 (permalink)
coolsunny's Avatar
^^thanks for reply.it gives new information.
But i think 17" suits me more.it will take less space.& for gaming its suits more as total space is less i can get suitable resolution for games.I don't have plan to buy grafix card in near future. & va 1703wb model have simplicity & it has good reviews on newegg site.so its my choice.
& VX 1932WM model has some problems.may be few defective products.i viewed thread .. Problem with Viewsonic VX1932wm LCD
suggest a good tv tuner card with good recording capability NiluGeek Hardware Q&A 1 06-10-2007 08:28 PM
Suggest a Good 29" Television in range of 15 - 25k sbhas2k QnA (read only) 2 28-11-2006 09:04 PM
*EDITED* Need Good Set Of 2.1 Speakers under "2000Rs." dragonball Audio 14 17-12-2004 09:40 AM
